Blue 67
![]() Join Date: Apr 2004
Doesn't want to start
Hey guys;
Truck was sitting for 12-18 months and I didn't get change to prepare it for long storage due to work. Now that I need to move it, it doesn't want to start. I put fresh gas in it and checked all the fluids. Engine turns, I have fuel and spark but it just cranks with no luck. Any help would be appreciated.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
Re: Doesn't want to start
Do you see gas shooting from the accelerator pump nozzles when you open the throttle quickly?
Get a can of spray B12 Chemtool. Shoot some down the carb with the throttle open a bit. Crank it. |
Hi , do you have a HEI coil ? Also check ignition ?
Blue 67
Yes, I do have HEI.
Blue 67
Will try it tomorrow since I don't have any on hand at this moment. Thanks.
If you've got carb cleaner spray that usually works too.
Chances are the inside of the carb is corroded with white stuff due to the ethanol in the gas and it attracting water. What carb is it? |
Blue 67
It is Edelbrock, 1406 if I remember correctly. I will pickup some cleaner on my way home.
Blue 67
Carb cleaner did the job!
Thank you all.
