Old 07-09-2014, 11:25 AM   #1
DylanVK
Help with door alignment
So first a little background - as best I can tell I am the 4th owner of this truck since it became a 'project truck' and other than going over it with a fine tooth comb to see the sheetmetal and body work were done properly I don't have much info on how/who did a lot of the work.
Bulk of the cab and bed restoration were done 3 owners ago and everything is gapped really well, save for one spot on the drivers door where I have the door rubbing the drip rail (see pics)
Looking for some advice as to how I can tighten this up. Never done a door alignment on a truck like this before so its all new to me. Thanks in advance for any tips/tricks/advice.
It barely rubs on open/close - the leading edge gaps all look decent, maybe a little wide, so I have room there to pull the door forward I guess. Just looking for input on how I should proceed.
DylanVK is offline   Reply With Quote
Old 07-09-2014, 12:20 PM   #2
notsolo
notsolo's Avatar
Re: Help with door alignment
How are the hinges any movement when you lift the door? You may be able to move the top hinge in a fraction, it is very difficult to get at the hinges. I think I had the cowl off and the fender loose to get at the top hinge bolts, mark where the bolt is and number of shims. Get a roll of blue tape to protect the paint edges. Truck Color is great BTW.
notsolo is offline   Reply With Quote
Old 07-09-2014, 01:16 PM   #3
SuperC10Tex
SuperC10Tex's Avatar
Loosen top cap hinge bolts, use a floor jack with a 2x4, left off center on the door....."just a bit", tighten bolts and see what you get! Play with it!!! Oh, loving the Color, more pics please????
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 07-09-2014, 05:09 PM   #4
jjdowney
Subscribing, I have a similar problem but my issue is on the opposite side. Mine is rubbing close to the hinge.
jjdowney is offline   Reply With Quote
Old 07-09-2014, 05:47 PM   #5
Molberg
Molberg's Avatar
Check your hinge pins and bushings with a lift and release on the outer edge of the door. If worn badly... Will cause top corner opposite hinges to fall.
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 07-09-2014, 09:38 PM   #6
67ctener
67ctener's Avatar
Idk how to fix it but beautiful paint
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 07-09-2014, 10:34 PM   #7
hugger6933
Grab the back of your door and see if you can shake it up and down. If there is any slack there it needs to be taken out before going forward. Just remember the body side bolts will adjust the door forwards and backwards. the door side hinge bolts will adjust the door in and out. Now you can if needed get a small amount of twist in either one with the use of a shim. but looking at the pics of the truck in question I say it hopefully needs some bushings in the hinges. That will be a lot easier to fix than will loosening the hinge bolts with the fenders on with out the fender wrench. If you don't have the special Kent Moore wrench or the Snap-On cousin, maybe try a Crescent [not wrench but shape] wrench to see if it will work a lot of times they will. I hope I have at least not done any harm in you trying to adjust the door on your truck. Jim
hugger6933 is offline   Reply With Quote
Old 07-10-2014, 10:19 AM   #8
DylanVK
Thanks for all the help... I'll be giving some of these suggestions a try this weekend. Also cutting out the rollpan and hideous tail lights installed by the previous owner and reinstalling a modded stock bumper - more pics of that little project to come.
A tiny bit... just enough to pull up and avoid the rub, so I've take to (at least for now) pulling up a little on the door handle when closing the door to avoid making the rub spot worse.
Thanks... and heres a few pics of my baby
Thank you!
Great input... thank you. I may have to track down my buddy in the snapon truck this week and try to grab that wrench from him.
Old 07-10-2014, 02:02 PM   #9
RenoKeene
Florida Edition
RenoKeene's Avatar
A bit of good advice...get yourself some 3m painters tape and tape all the edges of the door and the cab before you start adjusting. Hate to see anymore chips in that pretty paint job.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 07-11-2014, 08:45 AM   #10
Lemield
Lemield's Avatar
Hey DylanVK,
I have a door holding jack that makes working on doors much easier. I used it on my truck(s) and it's just sitting in my attic right now. You are most welcome to borrow it if you want to. I'm in Arvada. Just let me know.
Oh...and your truck is beautiful.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 07-11-2014, 01:05 PM   #11
DylanVK
Hey Larry! Thats extremely kind and generous of you... I may take you up on that if I can't manage to get it dialed in with it on the truck.
Also, nice to 'meet you' neighbor
Old 07-11-2014, 08:19 PM   #12
Sammy
Whoaaaa...there is such an animal?? Nice a door holding jack..beats my hyd jack n 4X4..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-14-2014, 03:34 PM   #13
Lemield
Lemield's Avatar
No problem buddy...just let me know if you want to use it.
Larry
Old 07-14-2014, 06:53 PM   #14
hotrodder
would you mind telling what size wheels and tire size you have on the truck? I have a 67 and I am looking for some wheels and tires. COOL TRUCK!
hotrodder is offline   Reply With Quote
Old 07-14-2014, 07:00 PM   #15
Tinkermc
From what I read here you should get the door perfect. You Sir, have an awsome lookin ride and the color is great!!!
Tinkermc is offline   Reply With Quote
