Old 07-09-2014, 12:38 PM   #1
Hugh Mongus
Trans kickdown bracket
Can anyone tell me where I could get a kick down bracket for a TH350 that will work with vortec heads/intake?
I bought the vortec bracket from Jegs but it doesn't work.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 07-09-2014, 02:32 PM   #2
bigmac73
bigmac73's Avatar
Re: Trans kickdown bracket
i had to buy the edelbrock black bracket and so some minor cutting and welding to make it work, but it still dose not allow the throttle to open all the way
i asked Summit racing they suggested trick flow (TFS-20000) bracket. I have not bought it yet
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-09-2014, 03:05 PM   #3
Procurement_man
Procurement_man's Avatar
Holley 20-95 will do Trans and accelerator mounts off the carb stud.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel
Procurement_man is offline   Reply With Quote
Old 07-10-2014, 09:05 AM   #4
bigmac73
bigmac73's Avatar
I have the Holley 20-95 now , but it is too close for the kickdown cable and I guess i my cable is too long??
Mike
Old 07-11-2014, 04:09 PM   #5
Hugh Mongus
Could someone post a picture of there kick down setup that has converted to vortec heads please? Preferably with a TH350.
-Jason
USN Retired
Old 07-11-2014, 08:11 PM   #6
Sammy
If I remember correctly it took some slight mods to get mine to fit correctly...Holley carb..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 07-12-2014, 08:04 AM   #7
Hugh Mongus
-Jason
USN Retired
