07-09-2014, 05:31 PM | #1 |
lowering a 71 swb step side
I apologize if this has already bean answered but i am not sure on what to buy. as i am in the united kingdom these parts are not easy to come by
I have just bought a 71 swb c10 stepside, which this is not at present lowered i have seen some pictures on here with a 5 inch drop on the rear and a spindle change and a 1 inch drop spring on the front. What spindles do i need because the truck already has disc brakes on and that is mainly where i am getting confused. do i need to get shorter shock absorbers, and i have also seen brackets to relocate them , is this necessary? and also a shorter sway bar? again any help would be most welcome. a few pictures of lowered ones would also help me deciding what drop to go.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
07-09-2014, 05:57 PM | #2 |
Re: lowering a 71 swb step side
You got it. Just put drop springs in rear. Some people say they get away with no C notch on a 6 inch drop but I think most do c notch the frame after 4 inch to keep the axle from hitting frame. On the front you don't want too much drop spring. You nailed it: 2 inch spindles and 2 inch springs. Your disk brakes on front are common on 71-72 trucks so you won't have any problem finding spindles. Try searching this site or use Google and click on the posts for this site.
