07-09-2014, 07:07 PM | #1 |
What the heck is this brass fitting for?
While Jim Pontius has been helping me sort out the various braces that mount the 72 3/4 ton disc setup, I found a reference photo that shows a brass fitting on the master cylinder that I have NOT installed yet. Actually, I have the fitting but didn't know where it went until all the digging.
It's marked as K/H (D) 78497 Googled that many ways to no avail. Male port goes into MC, line from combo valve into female port, and an unused-in-the-picture small (3/16" ?) port on top. Remember that on the 3/4 ton the front is the rear brakes and vice versa, so this would be on the rear brake side of the system. It's not a residual pressure valve, as you can see straight through it. So, anyone know what the heck this T is for? Heaven hope they never made a hydraulic trailer brake setup that took pressure from the master cylinder of the tow vehicle!
07-09-2014, 07:18 PM | #2 |
Re: What the heck is this brass fitting for?
The old style trailer brake controllers T'd into the line like that.
07-09-2014, 07:18 PM | #3 |
70+ ( Old Skool Club )
Back in the day before trucks had lots of electronics when you wanted to hook up a trailer brake to had to physically cut into a brake line and run a hard line to the brake in the cab of the truck so I'm pretty sure that is what the t-fitting is for.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
07-09-2014, 07:20 PM | #4 | |
07-09-2014, 07:29 PM | #5 |
Crazy. Guess it worked though! Given the complexity of things like cruise control and air conditioning I'm surprised they couldn't come up with an inertial controller by that point. They made it to the moon using inertial guidance, so you should be able to stop a trailer :-)
07-09-2014, 07:41 PM | #6 |
Yep, An added tee to allow routing brake fluid to a controller that in turn sent an electrical current to the trailer brakes. Easy to install and easy to use. Funny how many trucks still have them with the controller pulled off and even after a M/C change. If you look through truck handbooks from the 70s you will see warnings about not using trailer brake systems that tap fluid from the master cylinder or more than "x" amout of fluid. Just changing technology.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-09-2014, 08:06 PM | #7 |
Yup, a change in technology that was, in part, prompted by the advent of anti-lock brakes. Interesting to note is that new GM and Ram trucks with the integrated brake controllers utilize an inertia system. I've heard that Ford relies on a brake system pressure reading. Frankly, I'd have more confidence in the Ford system.
07-09-2014, 10:21 PM | #8 | |
07-10-2014, 11:17 AM | #9 |
Most of the trucks I run across have a trailer brake set-up like that. If there's not a little box with a lever on it under the dash between the parking brake handle and the steering column, there'll be a line from the tee fitting to it. I've got a collection of them in my storage area in the shop AKA 'house of horrors'.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
07-10-2014, 11:54 AM | #10 | ||
"I ain't nobody, dork."
My '72 GMC was the only truck of this vintage I have owned that did not have a brass T-fitting in the brake line for a trailer brake controller. The '67, '69 and my Dad's '70 all have that fitting installed for a brake controller. I have installed a few of those myself in the past.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
