07-09-2014, 08:28 PM | #1 |
drum to disk conversion
Good evening,
I hate to keep beating the bush on this, but I would like some more clarification on this conversion. Like Ive mentioned before, I found a 71 GMC donor truck and gutted the whole front end out of it. I then blasted and painted it, replaced the ball joints, bearings, seals, rotors, calipers, etc.. It is new and ready to go. I have since been in a bad motorcycle accident, which has destroyed my right leg and am unable to perform this swap. Can I use the upper and lower control arms and spindles and get this done, rather than doing the whole front cross member? Or can I put the new ball joints in my existing 68 control arms, and go that route? I just want to get the truck off jack stands, and out of the garage to cruze around in. I will do the rest later when Im feeling better. Any help would be greatly appreciated. |
07-09-2014, 08:36 PM | #2 |
67-72 parts collector,…
Re: drum to disk conversion
Use everything from the a-arms out,... plus the 71-72 steering linkage from the donor truck.
07-09-2014, 08:37 PM | #3 |
I've never been a fan of swapping out the entire crossmember,...
07-09-2014, 11:16 PM | #4 |
Hey miniman ...
In case I missed you ... I just want to say to the forums
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
