07-10-2014, 09:05 AM | #1 |
Door drain holes
My driver side door is retaining water.
1. Can anyone show me where the door drain holes should be located? 2. If I have to put in new holes, any suggestions on placement & treatment? Thanks in advance |
07-14-2014, 09:02 AM | #2 |
Re: Door drain holes
Well that was easier than expected. I found a couple slots that were just clogged with debris.
07-14-2014, 10:13 AM | #3 |
What?
I would get a brush with a handle, so that you can reach around inside the door with it. Brush all along the bottom of the door the best you can, then take a shop vac and vacuum out any more debris that may be in there.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-14-2014, 10:54 AM | #4 |
test
07-14-2014, 10:57 AM | #5 |
I'll keep that in mind. I just blew out the debris and put it back together since I was primarily working on the weatherstripping. I'd like to spray the rust too but the stuff I have is hard to breathe for a long time afterwards.
07-16-2014, 08:29 AM | #6 |
If it's not rusted out-I've found that a good brush coat of "POR-15" is the easiest and best way to fix it. Just be sure the POR 15 doesn't block the holes.
07-16-2014, 09:47 AM | #7 |
