Old 07-10-2014, 10:24 AM   #1
robber grin
Short Fleetside Braces
I tried to search this out, but had no luck - so please bear with me.
Don't the four (bolt-on rod) side panel braces mount to the Fleet side bed's cross-sills from the inside of the sill's channel with the sills mounted so the brace's mounting holes are on the forward (cab) side when installed?
Thanks... rg
robber grin is offline   Reply With Quote
Old 07-10-2014, 11:56 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Short Fleetside Braces
I have a '64 longbed, and that's the way mine was mounted from the factory. I moved my bedfloor up, so I had to change it from the stock configuration.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 07-10-2014, 01:01 PM   #3
robber grin
I brought mine up 3" as well - so in addition to trying to remember how these go in, I have to figure out if another 3" of length will do (or what will) with the angle on each.
Thanks!
