![]() Join Date: Oct 2009
Where to find a plastic fast idle cam for a quadrajet from a 1969 396
My Dad is rebuilding the Quadrajet on a 1969 C10 396 truck I picked up and he found the fast idle cam on the right side of the carb is red plastic and cracked. He has owned and repair shop since 1972 and worked at a GM dealer in the late 60's and remembers the plastic breaking off and the throttles going open. I am trying to find a repair or replacement for this plastic coated lever. Any Ideas? The carb number is 7029214. I have another 1969 C10 396 carb and a 1972 C20 402 carb but neither one has this plastic lever. If it matters this truck is from the south and I think originally came from California. It does have a smog/ air pump set up on the engine. I can get pictures but Dad has the carb at his house right now and I have not been there yet to get any. Thanks for any help.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
Re: Where to find a plastic fast idle cam for a quadrajet from a 1969 396
I have some parts carbs. I will look tomorrow & see if I have one with that part.
George |
Cliff Rugles maybe.
One of the First
![]() Join Date: Jan 2000
Throw up a picture - I have a few older Q-Carbs.
Thanks guys, I will try to get to my Dad's tomorrow and get a couple pictures but it is a red plastic lever on the passenger side behind the choke linkage.
None of mine have it.
George |
Here are some pictures of the arm. Dad says if he remembers correctly they had different colors for different fast idle speeds.
Still no one has seen this plastic arm? I have the carb rebuilt but would like to figure this out before reinstalling. Thanks
I am sorry but I do not know Cliff Rugles? Is that his name on here. I did a quick search and did not find anything. Thanks
I just did a Google search instead of a forum search and found who you are talking about. I will check over there and see what I can find. Thanks
If perchance it should break it won't effect your normal idle speed. It'll effect your high idle speed when the choke is working.
If he dosen't have one he might give you some leads anyway. Another source might be V8Buick.com, a lot of those Buick guys run quads and there's quite a few retired GM employees.
#13 | |
Thanks again. I will check that out and see what I can find.
#14 |
![]() Join Date: Mar 2012
i have this carb with red cam, #29202 DH 0079. it was on my 72 402. i would trade for a 72 402 carb. let me know what ya have with numbers.
#15 |
I am really only wanting the red plastic arm part because I have the correct original carb for the 69 C10 396 but I do have an extra 402 carb that has these numbers on it. 7042206 1472 QA That I might trade.
#16 |
I think the part you are looking for is an aftermarket piece. The carb below is a big block divorced choke carb in stock trim and, if you look closely, you can see the metal casting used for the fast idle cam. Call or go to Quadrajetparts.com. They have it.
#17 |
![]() Join Date: May 2010
I can't help you find one, but my 69 with a 350 also has the red plastic cam. It is original to the truck, not an aftermarket piece. If you look closely you can see it in the picture below.
Keep up the search, and let us know where you find one. |
#18 |
Junior Member
Interesting. I've never seen anything other than the metal fast idle cams. Is this another '69 unique feature?
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
#19 |
[QUOTE=FirstOwner69;6910632] It is original to the truck, not an aftermarket piece.QUOTE]
And you know this how, exactly? |
#20 |
[quote=Fitz;6913187]His screenname is firstowner69 that might be a clue
69 Chevy 4x4 383 Power ![]() |
#21 |
member #16
![]() Join Date: Dec 1999
I also had a 69 I bought new with a plastic one.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#22 |
#23 | ||
Thanks for the information. I have the carb rebuilt and think I will just try it the way it is for now and try to come up with something before it breaks more. I will let you guys know if I figure out something. Thanks everyone.
#24 |
![]() Join Date: May 2007
When I was a kid, I bought a 69 Impala from my grandpa, that he purchased new. It had a 350 with a plastic cam q-jet. 69 is the latest I have ever seen them. Seems like I remember reading in a q-jet book, that they were used on early carbs.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#25 | |
The recall covered 1968-69 models by all GM divisions. |
