Old 07-10-2014, 04:45 PM   #1
ssuesens
ssuesens's Avatar
What's wrong with my TH350 tranny?
Trying to troubleshoot my son's TH350 AT in his '71 C10.
Yesterday it began sticking in gear (2nd gear I believe). After moving column shift to D, it's not shifting up or down and making a soft whirring or whining noise on acceleration. I replaced and checked the vacuum line and verified the vacuum accumulator is getting and holding a vacuum. Also checked AT fluid level and its cherry red and full. Kickdown cable is not stuck or binding. I visually inspected the shift linkage and it appears to move through the motions correctly and Park, reverse, & neutral all are working fine. My next guess is looking at the governor but that's above my comfort & knowledge level. Any tips?
Anything else I can check prior to hauling it down to the tranny shop?
Thanks in advance!
"Life is too short to use cheap zip ties"
64 C10 SWB
71 C10 LWB
72 C10 LWB
ssuesens is offline   Reply With Quote
Old 07-10-2014, 05:13 PM   #2
trac209
Re: What's wrong with my TH350 tranny?
I'd check to make sure the filter isn't clogged in the pan for starters.
trac209 is offline   Reply With Quote
Old 07-10-2014, 05:43 PM   #3
geezer#99
geezer#99's Avatar
Pull the dipstick and smell the fluid. If it smells like burnt toast then it's rebuild time.
Fluid should be pink not cherry red.
geezer#99 is online now   Reply With Quote
Old 07-10-2014, 06:55 PM   #4
Bigdav160
Bigdav160's Avatar
"soft whirring noise" sounds like a sun shell problem
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
