help with broken wheel stud
I just broke one of the studs on one of my front hubs. I have a 72 4x4 Jimmy with disc brakes in the front. Could someone please give me some simple instructions for changing the stud? I am having new wheels and tires mounted in the morning. The tire place won't change the stud. I am trying to paint some of the hub area before the new wheels and tires. Thanks in advance for your help.
LT |
there is no easy way you have to disassemble the entire hub and pound out the stud with a punch and hammer.
1990 subaru legcy (daily driver) 1987 Toyota 4runner (weekend toy) 1968 ![]() 1970 ![]() 1976 Dodge Dart 1963 Dodge Dart ![]() |
Once you get the old stud out, you can "pull" the new stud into place by using a regular wheel nut. If you put on a couple of greased up washers, screw the nut on with the taper out and then tighten the nut up and you can pull the stud into place. I use an impact wrench to speed it up.
Jim |
