larger front rims on a Task Force
Has anyone tried putting a 20" rim on a stock 6 lug solid axle? Would like to see some pictures. Not Mustang II or clipped, stock solid axle.
More thoughts on this. I am throwing around some different rim ideas. I really like the look of a 19 front and 20 rear. Problems are rotating goes out the window. 20" 6 lug rims are abundant so lets go with that My calculations look like this. Current combo is 205/75/15 on a 15x6 rim, 82mm of backspace. This setup is very close to the tie rod. Looks to have about 2" of room to fender. Question combo would be 245/45/20 on a 20 x 8.5" rim, 127mm of backspace The calculator says the 20 combo would be 1.3" closer to the suspension, due to offset. I believe I have two options. 1. 2" wheel spacers to move the wheel outboard 2. 1.5" wheel spacers and "adjust" the steering arms for a bit more clearance. Sid says Ackerman will be fine. Any thoughts, successes, trials or failures are welcome. Thanks!!! Last edited by sqrlnts; 07-10-2014 at 09:37 PM. |
![]() Join Date: Aug 2010
Re: larger front rims on a Task Force
Well clearance is a bit tight.
Here is an example , my '56 with 15x7 front & 15x8 rear wheels with 31x10.5 tires. The rear tires rub their sidewalls on the fender lip when there is a load in the bed. The rear wheel is slightly reversed, if it was a standard offset it would allow the tire to clear the fender. The left front tire inner sidewall rubs the drag link when making a tight left turn.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
As for 20's your wheel should clear the tie rod BUT the drag link is another story.
My tire has a nice groove cut in it from the edge of the drag link when making a left turn. I think by its location it would be just about the the bead area of you combo. This would make a left turn a "bit" wider then a right turn. A solution would be an aftermarket available solid axle rack & pinion steering system. If you planning on lowering, fender clearance would be the limiting factor. Your best bet would be to visit a tire shop that has the wheel and test fit the wheel on the left front and rear. This will show what restrictions the steering system presents. You then can get a feel about how the tire might fit. This would only cost a few bucks and answer a lot of questions. BTW I hope your planning on a disc brake conversion for at least the front and a duel master cylinder system.
When I bought my 57 it had 20" KMC Rockstars on it... they rubbed the drag link badly and looked absolutely terrible on the truck so I sold them ASAP. This is the only picture I can find here at work with the 20's on it:
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels |
polishing a turd
^ good move getting rid of those!
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
Why just rims?
Why not get hubs and spokes to go along with them and have complete wheels? (the term 'rims' is a pet peeve of mine...)
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
re rubbing the drag link on left turns: I had the same problem on my AD with
15X6 rims on the front. I welded a nut on the face of the bump stop - the angled piece that bolts to the king pin center pin ? - and that ended that problem. I don't notice any lack of left turn ability |
this... never did like rubber bands on big rims on a classic truck/car
i did like g&r and used 7x15 and 8x15 with 31'' tires on truk
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Here is a set of 16x7 white spoke wheel with 265/70R16's , they are 30" diameter. They offer a reasonable section height with the look of a larger wheel. The pic is for reference although the truck is a 57 GMC Napco 4x4 they would work on my 56 Chevy 2x4.
How do you feel about a set of 17" or 18" Rally wheels ?
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 Last edited by G&R's57GMC; 07-11-2014 at 11:16 PM. |
To me wheels bigger than 16 inch just look silly on most older trucks. Part of that may be because the local tire stores seem to only be interested in selling the gaudiest, most garish and ugly 20 and + rims that they can can drag in as the local individuals who run them tend to like that in anything they have.
This one was for sale on craigslist a while back. ![]()
I've been wondering of the Rocket Hypershot 6 would fit with little issue myself. I think they only come in a 20x9 though. I wouldn't mind having a set to put on every now and then, but would probably run the 15x8 with wide whites like I do now most of the time.
#13 | ||
I have come to the conclusion that 20's wont work, not that I really wanted a wheel that big but found a good looking set cheap on craigslist, damn you craigslist. I like the front wheel well to have as much tire/wheel in it as possible, for me 15's dont really cut it. My 6x139.7 bolt pattern and odd 3.56" hub OD almost guarantee's the need for a spacer. I think the smart route, for me, will be to save the money and put it toward my front suspension redo budget which, will require new wheels!!! ![]() Now I just need to figure out how to incorporate a 5x4.5 lug pattern into the mix because, there are a TON of 5x114 wheels out there. |
