Old 07-10-2014, 10:51 PM   #1
Oldironracing
Oldironracing's Avatar
700R4 Trans. ??????
How's Trans are u guys using. Going behind a big block 500 to 550 HP. You can read anything but would like hear what u guys have used and the pro and cons.
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 07-11-2014, 08:28 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 700R4 Trans. ??????
A 700R4 will not be happy behind a big block. It's not the horsepower but the torque.
It'll work OK for a while then break. I had a '67 SWB with a 396 - 700R4 combination. Two years later I pull it to freshen it up and install the drivetrain in a '63 SWB. I could hardly believe how beat the transmission was.
A 400 or 4L803 is a better choice behind a BB
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-11-2014, 09:42 AM   #3
Lee H
Lee H's Avatar
Check out Bowtie Overdrives. They have a 700R4 that will hold up with your motor. I have a few friends running running them with no problems. I have talked to BTO in person about my truck (400TQ @ RW) and will be going with them when my THM350 gives up. They have a very, very low return rate. I'm sure there are others building stout 700s but have not checked them out.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-11-2014, 10:21 AM   #4
jjzepplin
jjzepplin's Avatar
Built mine with BM internals Long Long time ago. Flawless behind my 406. Not 500 hp though.
I might do a 4l80 if I had the coin and know how for the programming.
But for the money this was my best choice and it was a good one.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-11-2014, 05:48 PM   #5
big d's red67
big d's red67's Avatar
I have a 700r4 behind my 525hp 630ft big block and its great. just make sure you get one built to stand up behind your engine. Phoenix Trans is where mine came from, and they built it to stand up to my HP and torque.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 07-11-2014, 09:18 PM   #6
Turbo1dr
Turbo1dr's Avatar
I have a 200-4R behind a 600 rear wheel horsepower turbo V6. It's been holding fine for the last 5 years. I like those better than the 700, 4L60 or the 4L80's. THey arent as heavy and they have a better gear spread with a *deeper* overdrive for cruising. A lot of people go *overkill* on super heavy duty *bigger is better* theory. Not true these days.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored
1978 Turbo Malibu - Owned since 1986
1987 Grand National Aerocoupe -1 of 1
1988 LeSabre T-Type - Supercharged
Turbo1dr is offline   Reply With Quote
Old 07-11-2014, 09:48 PM   #7
hugger6933
I would go with a built 200R4 before the 700R4, but in my case with neither of those laying around my yard and there is [3] 4L80E's sitting out back If either of the two big block trucks I'm building they might get a 4l80E, but then there is the expense of the stand alone shifter computer and that makes up a lot of the build cost to a good built 700. I have had good luck in the past with 700's behind a 468 in a extra cab Silverado that ended up in a new home being used to pull a horse trailer and they never had a trans related problem. Jim
hugger6933 is offline   Reply With Quote
Old 07-11-2014, 11:08 PM   #8
Oldironracing
Thanks guys. Have already talked to bowtie. There's a lot to do with all that pressure gaug stuff to activate the warranty. Been told that linkage thing they sell for carbs is not really nessary if you use a double adjustable cable. Have a friend that has a phonixe Trans and loves it bout have heard they have lots of returns. Just not sure......
OLDIRONRACING
