Old 07-11-2014, 02:57 AM   #1
kamwil05
1972 chevy k20
Alright so I have this 1972 chevy k20 that i was given for my birthday and after having it for about 5 months it got rear ended, the bed is pretty well ruined and the frame is possibly bent. I would like to fix this truck and get it back on the road, but I dont know what i should do, throw a flatbed on it? maybe find a used bed? I want to do something really cool to this truck maybe make it an offroad truck? I dunno I need some ideas! thanks!
kamwil05 is offline   Reply With Quote
Old 07-11-2014, 06:33 AM   #2
Re: 1972 chevy k20
Welcome to the site! Where is Filmore? Just gauging your chances of finding a decent bed for reasonable money. You could build a flatbed. I've seen some cool off road versions. You could build a box like a Stepside bed and either bolt on Stepside fenders or fab some from steel
Here are a few. I know Yukon Jack owns the last one. Not sure on the others:
Old 07-11-2014, 01:47 PM   #3
kamwil05
Re: 1972 chevy k20
hey thanks for the reply! Fillmore is a small town in Utah! I have looked at doin a flatbed and i kinda like the way they look! do you think that would be the best option for me?
Old 07-11-2014, 10:06 PM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1972 chevy k20
Show us some pics....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 07-12-2014, 09:14 AM   #5
Re: 1972 chevy k20
Could be cheapest,unless you can grab a decent bed from a pic-n-pull. I asked where Fillmore is to get an idea on what part of the country you're in and your chances for finding a good used bed. Utah is vast,but if you're near any good pic-n-pulls there's a good chance of finding a good used bed. The cost of all new sheet metal is a couple few thousand. The cost of the flatbed depends a lot on size and design. Steel ain't cheap but that's your whole cost,other than welding supplies,if you do it yourself. Might find a bigger flatbed you can cut down and save on steel
Old 07-12-2014, 10:04 AM   #6
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 1972 chevy k20
Like Tim says I would think you're odds of finding a decent used bed are pretty good out west where you are.
One more thing:
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-15-2014, 02:10 AM   #7
kamwil05
Re: 1972 chevy k20
Alright so i have located a flatbed for $120 bucks or a 71 bed for $175 which one is gonna be the best for my truck?
Old 07-15-2014, 08:23 AM   #8
Ol Blue K20
Re: 1972 chevy k20
Need pics to make an assessment
Dale
Old 09-25-2014, 05:59 PM   #9
kamwil05
Re: 1972 chevy k20
Ok guys Sorry for not getting back with you for such a long time. So I decided to get rid of the idea to just replace the bed. I found a 1984 chevy that has a 1991 cummins in it with a 5 speed manual tranny,when they did the conversion they just put the cab and bed on the dodges frame. so this truck has a few things that needs to be fixed, 2nd gear is pretty well gone and it needs a new starter, they are asking 2,000 dollars for it. Is this a good deal? and also how hard would it be to swap cabs with my 72?
Old 09-25-2014, 08:42 PM   #10
57taskforce
All about them K’s
57taskforce's Avatar
Re: 1972 chevy k20
After having done a cab swap on my 57, I would suggest it as a last resort. It's pretty labor intensive and requires time and good fab skills to pull off correctly. My truck came out really good but I doubt I'll ever do it again.
Tyler
57taskforce is offline   Reply With Quote
Old 09-25-2014, 09:56 PM   #11
Vintage Windmills
Vintage 4x4s
Re: 1972 chevy k20
Yes that's a good deal, especially if 91.5 or newer with intercooler. Getrag setup with np205 and dana 60 together are worth that. I would rather have the chevy frame with the dodge driveline but you can't go wrong buying it even for parts
Old 09-25-2014, 11:28 PM   #12
kamwil05
Re: 1972 chevy k20
thanks for the info! i was thinking it was a pretty good deal! but the only downside is its not intercooled, is that still a good deal?
Old 09-25-2014, 11:29 PM   #13
kamwil05
Re: 1972 chevy k20
Hey thanks for the reply! just out of curiosity what is the hardest part about doing a cab swap?
Old 09-26-2014, 04:01 PM   #14
57taskforce
All about them K’s
Re: 1972 chevy k20
Making the cab mounts/core support mounts the correct height and placing them in the correct places on the frame so the front sheet metal lines up to the cab and centers the body side to side and level on the frame. I started with the cab resting on 4x4 blocks of wood on the frame them moved it around till it was positioned so the front fenders lined up to the wheels and everything was level and centered. Then fabbed the cab mounts out of steel plate. After the cab and front clip were mounted I mounted the bed. The other thing you'll have to likely deal with is the wheel base being wrong, which means moving the axle or lengthening or shortening the frame... It's a lot of work.
Tyler
