07-11-2014, 09:12 AM | #1 |
Rear window question.
I have '67 C10 with the large rear window.
At some time someone installed a slider. I have the original window that I want to put back in and sell the slider. My question is, are all '67-'72 rear windows the same, and will it fit other years also. Thanks Donzie
'92 GMC Suburban 1500. 153K miles (when purchased), super clean inside and out. '67 C10 swb. 350/700R. Solid TX truck. |
07-11-2014, 10:23 AM | #2 |
Re: Rear window question.
67-72 large rears are all the same. Will not fit any other year
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
07-11-2014, 10:44 AM | #3 |
Thanks!!
07-12-2014, 11:01 AM | #4 |
Orange Truck
Since you must reinstall the rear window, it is a good time to consider the SS trim for the window if your truck does not have it. It merely requires the SS trim (LMC about $60 and the rubber to accommodate it There is a difference in the rubber gasket.)
07-12-2014, 11:45 AM | #5 |
Thanks OT, I'll look into that.
07-12-2014, 11:48 AM | #6 |
A little helpful hint about the chrome be sure it is the 67 one. The earlier one had a shallower depth on the groove that holds the stainless trim and it is easier to install the window. Weather or not you do the trim I would look into a new rubber. Jim
07-12-2014, 02:31 PM | #7 |
Wow, you guys are a fountain of information.
Thanks to all. This my first truck project so I can use all the info I can get.
