Old 07-11-2014, 05:29 PM   #1
blue57
blue57's Avatar
Sanderson Headers
Anyone running them.......Gaskets or UTV?
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 07-11-2014, 09:46 PM   #2
Kim57
Kim57's Avatar
Re: Sanderson Headers
I'm using them with gaskets.
Haven't started it yet so have no idea how its going to work.
The guy I bought mine from recommended gaskets.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-11-2014, 09:58 PM   #3
trayallen72
i got sanderson headers and remflex gaskets not started it yet so not sure how well they will work got a buddy has sanderson he likes them no problems so far been on his truck 2 years with aluminum gaskets
trayallen72 is offline   Reply With Quote
Old 07-11-2014, 10:10 PM   #4
68c10airstream
68c10airstream's Avatar
High blue57, as a past ase dealer mechanic fixing every possible type of exhaust leak this is what i did with my sanderson tight tuck headers in my 68 c10 with a 2001 5.3. I used the revised gm exhaust manifold to head bolts. Unless the manifold gasket is a embossed stainless steel, i always use rtv silicone (oxygen sensor safe). When fixing motor homes with leaking manifolds we would shave the manifolds flat, use rtv and bolt on right away. This was the only way that lasted. With a thick composition gasket what happens is the gasket collapses under the prevailing torque and now it's loose and the narrow opening is like a blow torch. I had trouble with the 3 bolt collector gasket every year so this winter i took the headers off and cut off the 3 bolt collector and tig welded on v band clamps i purchased from ebay. Zero leakage and very serviceable, and clean and tidy. The sanderson headers are for 68 and up nova with a ls.
68c10airstream is offline   Reply With Quote
Old 07-15-2014, 02:30 AM   #5
Gobuffalo
Gobuffalo's Avatar
I tried soft copper, leaked like a sieve. Used ultra black RTV, hasn't leaked in years.
Gobuffalo is offline   Reply With Quote
Old 07-16-2014, 02:20 PM   #6
gvnick
I'm also running black RTV and no gaskets on my Sandersons. No leaks in 3 years daily drivin.
69 GMC shortbed
Carbed LM4 - Manual VB TH350 - Gear Vendors OD
gvnick is offline   Reply With Quote
Old 07-16-2014, 04:38 PM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I only used the RTV per their instructions on my shorties. hasnt leaked yet ( since 2009)
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
