Old 07-11-2014, 07:56 PM   #1
rdgt67
250 cid oil pressure
What are done 250 cid oil pressures. Mine runs 25 at 55-60 and 10-15 at idle.
rdgt67 is offline   Reply With Quote
Old 07-12-2014, 02:12 PM   #2
mechanicalman
Re: 250 cid oil pressure
You need about 10 lbs per 1,000 RPM roughly, so you are good at idle. Usually low oil pressure shows up worse at idle than at speed so, having said that, I'd consider using another gauge to verify.
mechanicalman is offline   Reply With Quote
