Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 07-12-2014, 09:01 AM   #1
ld271
wtb-transfer case boot trim ring and front drive shaft for 70 blazer auto
I'm looking for a transfer case boot trim ring and also a front drive shaft for 70 blazer automatic. Probably obvious but it's a high hump and shifter's on the column.
ld271 is offline   Reply With Quote
Old 07-12-2014, 07:16 PM   #2
JimH2828
Re: wtb-transfer case boot trim ring and front drive shaft for 70 blazer auto
I have these...all 3 are 4x4 shifter stick boot rings. Left one is a 69-70 and right ones are 71-72.
-Jim
JimH2828 is offline   Reply With Quote
Old 07-13-2014, 10:19 AM   #3
JimH2828
I found a front drive shaft for you.. Off an original 70 Blazer with Dana 44 front and NP 205 transfer case. Front diff yoke in very good shape. CV knuckle in good shape. The transfer case yoke is pitted. You will definitely want to replace the U-joints and centering socket that is in the middle of the knuckle joint. I'll price it right at $115 shipped.....the yoke and knuckle are worth that. It's 1310 u-joints all around. Collapsed length is 27 1/2".
Size:  58.2 KB Name:  20140713_100041.jpg
-Jim
Old 07-13-2014, 03:58 PM   #4
ld271
Awesome. I'll take the drive shaft for sure. The 70 trim ring looks correct. Here's a couple pics next to tape measure to make sure. If it looks close, I'll take it too. PM me with your info. Thanks, Larry
Old 07-15-2014, 04:01 PM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Jim, should be correct. That looks like the correct trim ring off of the early np205 blazers. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
