need expert on brake hoses
I have a problem with my ft brake hoses on my 61k10. my wheel cyl's are 3/8-24 and my hoses are 7/16-20. I have some brass adapters, but they only catch a few threads. the wheel cyl's with 7/16-20 ports bolt on in a straight line as mine bolt one on top and the other side is at the bottom.
so have my lines custom made? Ron--any info on this?
1961 chevy K10 my build is------------61K10 build |
![]() Join Date: Aug 2008
Re: need expert on brake hoses
Kimble, I assume this an issue for the rear only? If I were you I would bend new 3/8" tube to match what you've got running along the rear axle and then get the appropriate 7/16-20 threaded double flare fitting made for 3/8" tube. You can buy the fittings from many places. I don't like to run adapters like that if I can avoid it. Just one more potential leak point.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
![]() Join Date: Mar 2003
Service Center Radiator in Auburn can make you a custom hose with the proper length and fittings, pressure checked and everything
Jason--these are the front. i think they changed in 64/64? I might have found some hoses, will post up if they work.
kwmech--thanks for the info, close enough to me to have some made if my new ones don't work.
Oh, I didn't realize that you still had the original front axle.
tk is all org. except eng-radiator/shroud-p/s and wiring.
The easiest thing would probably be to get the wheel cylinders with the 7/16 ports. Look at the Dorman W14494 and W14493 on rockauto.com. They should work. I have a set of cylinders sitting in my basement with 3/8 ports. I figured out they were the wrong ones when I went to put the hoses on....
Max--they bolt on different. they changed in late 63 to the straight across bolt pattern. the hose that is listed for 60-62 is wrong as it is the later hose.
I see your problem. A brass adapter will probably not fit your wheel cylinder. I believe the cylinder has machine thread, not tube thread. Dorman lists a hose #H34466. It says it has a 3/8 male end one one side and a 5/8 male with 7/16 internal (should be the frame) side. Maybe that could work?
I ordered the hoses, can't remember where i got the org one's from. we will see? I used some hoses from a 63 ford 4x4 that are 3/8 on both ends and used some banjo bolts in 3/8. had to shorten them some and does work. no leaks. maybe my first hoses were wrong? thanks for the info Maxwoof--will post up what i find out.
H34466 are the same as my first ones 7/16-20 male. I guess if i change what i have i will have to have some made.
well i figured it out. I just drilled out the 3/8 threads, and re-taped to 7/16-20. used one of my old/new cyl's.
