Old 07-12-2014, 06:30 PM   #1
Blakeman350
Blakeman350's Avatar
suspension question
Can anyone tell if front suspension parts off of a 88 to 98 two wheel drive gmc will bolt on my 67 gmc.
Blakeman350 is offline   Reply With Quote
Old 07-12-2014, 06:33 PM   #2
Wwildman
Re: suspension question
Sorry the only parts the I have used that work is 73-87 spindles and control arms
Wwildman is offline   Reply With Quote
Old 07-13-2014, 01:29 AM   #3
Blakeman350
I thought so just thought I'd ask. Thanks for the help.
Old 07-13-2014, 10:17 AM   #4
bdiamond
As far as direct bolt on, no. I've heard of someone using 88-98 spindles on a 73-87 type front suspension, but I'm pretty sure it wasn't a direct bolt on. As far as arms, they are way different. Sway bars might be made to work but still probably not direct bolt on. Not sure about springs....
bdiamond is offline   Reply With Quote
Old 07-13-2014, 10:49 AM   #5
Wwildman
Front springs will not work our trucks have a tapered spring at the top and 88-98 are open for the shock.
Old 07-20-2014, 02:35 AM   #6
deev8ed
deev8ed's Avatar
Can anyone tell me the benefits of swapping to a later model front suspension. Is it just for the disc brake conversion. I plan to put 2.5 drop spindles, new rotors, calipers, upper and lower control arms on my 65. If the swap is just for disc brakes I will just stick with my original 65 front end. Any help will be greatly appreciated.
deev8ed is offline   Reply With Quote
Old 07-20-2014, 03:00 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Use 63-70 drop spindles for a direct bolt on.
Add 73 rotors calipers and bearings.
71-72 master cylinder and prop valve.
Or aftermarket prop valve.
Keith
Convert to disc brakes.
Old 07-20-2014, 03:47 PM   #8
Andy4639
Old member
Andy4639's Avatar
Question Re: suspension question
So I'm going to ask...what is the benifit of the 73 and up calipor? Does it stop the truck faster is it bigger what? Just easier to find parts for?
The 71-72, 2 wheel drives are all disc brake front ends. How hard would it be to put a 2 wheel drive parts on a 4x4? I would think as easy are easier than buying newer stuff but I have never done it before. just wondering since you brought it up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-20-2014, 04:44 PM   #9
lolife99
lolife99's Avatar
73-up calipers are more readily available at auto parts stores.
The 71-72 trucks may even use the same part number now.
They both fit the HD 1.25" wide rotors.
Keith
