Old 07-12-2014, 10:41 PM   #1
Seanext
Rear spring hangers
I have what I was told was a 1972 short bed 4x4 frame. It came with correct front and rear axle numbers for that year. The rear had 54 inch springs. When I started looking at the mounting it was clear that it was originally 56 inch. The spring hanger were still riveted on so I know they had not been moved as there was no extra holes in the frame. I held a 52 inch spring in place on the front hanger and the spring mount for the front is about a 1/2 inch to wide for the spring. I looked close the hanger is still riveted no extra holes and the spring hanger is not bent. I have measured all the cab mount points and bed mounting points and it is correct for a 72. Did they use a wider spring in the rear for any reason? Was the GMC rear spring wider? I am scratching my head trying to figure out what is correct.
Seanext is offline   Reply With Quote
Old 07-13-2014, 02:05 PM   #2
argonaut
argonaut's Avatar
Re: Rear spring hangers
That is weird. All 72s would have used a 52" x 2.5" wide rear leaf. When holding a spring remember that the bushing adds another 1/2" or width. Also remember that the spring lengthens once the weight of the truck is put on it.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 07-13-2014, 04:17 PM   #3
Seanext
I have two other 4x4 frames and the spring hangers are about 1/2 inch wider where is spring mounts. Everything else measures the same on all the frames ( cab mounts, core support mounting, front springs, all cross members, everything works. Going crazy here trying to make sense of all of this.
Old 07-15-2014, 12:10 AM   #4
junksaver
67 & 68 4x4 trucks had 56" rear springs that are 3" wide. Do a search on those 2 years. The rear springs are odd balls compared to the other years.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 07-15-2014, 06:45 AM   #5
Seanext
Thanks for the info that makes more sense. I guess the next question is does anyone have a set of rear 56" springs the would like to part with?
