Old 07-13-2014, 12:07 AM   #1
s_nova69
what about a four link w solid axle and 4th coil overs
I am in planning on a family ride 72 4x4 suburban. I want all the comforts and to run a 32" tire. I can't have a HUGE lift. It will have a modern (maybe newest direct injected lt1) with some boost too.
I have thought about different ways to get a nice ride on the rig but don't think 52" springs will work with the ride height I want.
So how about building a custom/semi custom 4 link setup with a coil over setup. Then I can change spring rates and ride height easily. Being in Utah many jeepers build similar setups and so finding expertise on build details might not be to hard.
Anybody know of a setup somebody has built? Links?
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 07-13-2014, 12:08 AM   #2
s_nova69
Re: what about a four link w solid axle and 4th coil overs
I guess I needed to say a front end setup. Back will be easy enough.
Phil
Old 07-13-2014, 11:08 AM   #3
ryanroo
ryanroo's Avatar
Check out the build link in my signature. It's a long thread but there is a point where I cover the front suspension. It is a parallel for link with panhard using air bags. Might give you some reference
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 07-14-2014, 02:59 AM   #4
andrewmp6
Have you looked at http://offroaddesign.com/catalog/Fro...Conversion.htm
andrewmp6 is offline   Reply With Quote
Old 07-14-2014, 11:43 AM   #5
s_nova69
well well. Those are two things that I was thinking about.
Ryanroo- I travel the west and get down to Durango and south west Colorado on a regular basis as I work with mines. I would like to stop by and see ya some time if possible. Hit me a pm. AWESOME BUILD!!! I have a Longhorn as well.
I really do like the ORD design just by looks. I wonder if I can get it setup on a stock +2" setup. When I am ready I guess I will hit them up and see if that will work with such a low lift range.
Thanks for the info
Phil
Old 07-14-2014, 01:30 PM   #6
ryanroo
ryanroo's Avatar
Thanks! Sure thing! Let me know when you are going to be in the area and I can get you some directions and we can figure something out. I live a little east of durango.
72 K20 12v build
Old 07-16-2014, 02:15 AM   #7
Gobuffalo
Gobuffalo's Avatar
Pacific Fabrication has a nice set up.
Gobuffalo is offline   Reply With Quote
