Old 07-13-2014, 01:34 AM   #1
Cheyyenne81
Cheyyenne Autocross
Im looking to make my cheyenne a autocross truck on a budget. It has a 305 with a 4 speed. I have ordered drop spindles and lowering blocks for the rear, need to get sway bars for front and rear.. need some advice on modifications.
Should i stay with stock control arms and get polyurethane ball joints???
Cheyyenne81 is offline   Reply With Quote
Old 07-13-2014, 10:23 AM   #2
bdiamond
Re: Cheyyenne Autocross
http://67-72chevytrucks.com/vboard/s...ghlight=handle
This is a must read for you. Its long but well worth the read....
bdiamond is offline   Reply With Quote
Old 07-13-2014, 10:34 AM   #3
SkinnyG
SkinnyG's Avatar
Read the ruleset for sure. Pick a class, and build for the class. Unless you just want to have fun, in which case do what you want - just be prepared to be uncompetitive.
I ran H/Stock in an '86 Civic.
Then F/SP in a '94 Sentra.
Then D/Mod in a Super 7.
My truck will likely be E/Mod because of suspension and frame modifications.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-14-2014, 02:44 AM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
You have another vehicle to drive?
Kill weight wherever possible. The widest tires you can run with a 200tw rating or higher and a muncie for good gear spread and engine braking. 3:55-4:11 gearing should do most tracks. Getting it as low as possible with some really good shocks and moderate susp mods and you will have fun.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-17-2014, 03:31 PM   #5
Aaron_L
Lowering blocks won't work on these trucks, unless you've already flipped the rear. But even then I'd never run a block with a flip kit.
Aaron_L is offline   Reply With Quote
#autocross #cheyenne
