08-05-2003, 11:09 PM | #1 |
Need pic of x-fer skid plate
I was wanting a pic of a 67-72 factory transfer case skid plate if anyone has one. If it would be possible I would appreciate dimensions as well.
Thanks, Matthew
GOD is good...All the time! '71 swb custom10 barn find-68K original miles 72 K5 CST rust bucket, but runs and drives 84K miles |
08-06-2003, 10:40 AM | #2 |
anyone?
08-06-2003, 03:55 PM | #3 |
In my post. I will find it http://67-72chevytrucks.com/vboard/s...84#post472284.
Try this. It is not an original but an exact copy. I will post a pic tonight of the hole location. Mine is missing the last hole.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide Last edited by nu2-72; 08-06-2003 at 03:59 PM. |
08-06-2003, 04:14 PM | #4 |
If I am not mistaken, they also used a second frame cross member behind the transfer case to support the skid plate when the trucks were equipped with the factory skid plate.
Tim |
08-06-2003, 09:50 PM | #5 |
Pictures of both items are in the above link.
Here is another with the 1 1/2" hole layed out as provided by 68OrangeSunshine. Thanks for the help 68.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
08-07-2003, 12:11 AM | #6 |
thanks for the link and pic nu2-72. I was under the impression as well that there were two crossmembers, it that correct?
Thanks, Matthew
08-07-2003, 04:55 AM | #7 |
1) Yes, there is a second frame crossmember.
2) I'm not sure what that hole does, anyway? 3) I think my skid plate got run-over in the drive way, because mine has a curve to it that Nu2-72s unit does not have. My skidplate is off so I can deal with a leak issue-- it's either in the np205 or the sm465. I just keep adding 90 weight. HTH '68 O/S |
08-07-2003, 06:05 AM | #8 |
The plate is shown with the second crossmember attached. The other is still in my truck holding the tranny up. There is an offset. It is shown in the other pics. Here is the hole location.
