Old 07-13-2014, 07:52 PM   #1
jrigheimer
jrigheimer's Avatar
Proportioning valve confusion
I got this from my ece disc brake kit, but I don't know what outlets are for what. If the top is where the brake warning plug goes, the the two ports on the top go to the master cylinder and the one on the side to the rear and then the one on the bottom to the front brakes. It this right sorry if this is confusing. It the kit the have me a short line, what is it for?
jrigheimer is offline   Reply With Quote
Old 07-13-2014, 07:53 PM   #2
jrigheimer
jrigheimer's Avatar
Re: Proportioning valve confusion
What is this for, the rear brakes. What does it connect to
Old 07-13-2014, 07:54 PM   #3
jrigheimer
jrigheimer's Avatar
Old valve
Old 07-13-2014, 08:11 PM   #4
diggerbob
diggerbob's Avatar
I installed the ECE Disc conversion kit several months ago. You should have gotten a couple of smaller diameter brake line for your front discs. If I recall correctly, the brake line you showed is the one with a adapter to drop your line diameter down for the front discs. Here is what mine looks like installed...
diggerbob is offline   Reply With Quote
Old 07-13-2014, 09:14 PM   #5
mgchevyparts
mgchevyparts's Avatar
The fronts brakes can be front left and front right or you can plug one hole and run other to a Tee to front brakes. If you use a plug it must be an inverted flare plug to seal correctly.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 07-13-2014, 10:06 PM   #6
elf w/capital T
Mg . Thanks!!
elf w/capital T is offline   Reply With Quote
