08-05-2003, 11:18 PM | #1 |
Flat Seat spark plugs?
This might be a studip question, be what exactly are Flat seat spark plugs. Are those the R43 (13/16")? My 441 Heads are suppose to take flat head spark plugs, and I think the regular R44TS might be to long. Any help would be appreciated.
Nelson 1970 C10 350 Auto. A/C not Working |
08-05-2003, 11:45 PM | #2 |
ttt
08-05-2003, 11:49 PM | #3 |
a bit of a guess here but my recollection is that most newer models have spark plugs that have a tapered seat on them just above the threads. Older style heads had plugs with a flat seat and the washers that compressed a bit the first time the plugs were tightened in.
1968 Chevy - 292 with a powerglide |
08-06-2003, 02:15 AM | #4 |
I use R-44 in all my old style heads with the large plugs and dont forget the washers. biddaboy
08-06-2003, 03:08 AM | #5 |
any ac plug with a t in it stands for tapered seat which does not require a gasket and will not seat properly in early heads. i havent been able to find r44 or r45 plugs. can find r45s. the s stands for extended tip which means the shell doesnt shroud the tip. so stay away from a plug with a t after the number but any number alone or with a s after the number will work.
