07-14-2014, 07:36 AM | #1 |
those screws
I'm seeing these a lot during disassembly, the screw head is kind of a rounded off rectangle. I don't have a screwdriver for these. Anyone know what they are called? I'd post a picture but couldn't find one.
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
07-14-2014, 07:42 AM | #2 |
Re: those screws
Clutch screws
07-14-2014, 08:03 AM | #3 |
Re: those screws
ok..found them in google images. Now to find the bit that fits them. Thanks Shrek, by the way..how is donkey
07-14-2014, 08:37 AM | #4 |
Re: those screws
Harbor Freight sells a set of bits that comes with three sizes of clutch head bits. It cost about $10.
07-14-2014, 08:40 AM | #5 |
Re: those screws
Very easy to find. Search Clutch head bit, found 30 or so of them. Here's one.
http://www.ebay.com/itm/CTA-Tools-87..._Tools&vxp=mtr Harbor Freight has a 'security bit set' that has some in it too: http://www.harborfreight.com/100-pie...set-68457.html Enjoy.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
07-14-2014, 09:34 AM | #6 |
Re: those screws
Thank you gentlemen, I bought the set off ebay as it covers different sizes and will allow the extra leverage of a ratchet handle.
07-14-2014, 10:11 AM | #7 |
Re: those screws
I have not had much luck removing clutch heads that have been in for any length of time. With the ratchet you can get good leverage but the cluth heads strip easily, so the extra leverage is lost on the stripping of the head. I have done well just grabbing onto the head with a pair of Vice gripps and unscrewing them that way (assuming you have enough room).
Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
07-14-2014, 10:44 AM | #8 |
Re: those screws
I'm with Youngrodder on this one.
Spray any screw that's at all suspect with PB Blaster or your favorite rust penetrant before you try to remove it. The last 50-odd years haven't eased dis-assembly on this stuff. Not on mine anyway.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
07-14-2014, 10:50 AM | #9 |
Re: those screws
Plenty of PB blaster or another good rust penetrate goes a long ways towards getting them out. Sprayed from the back side to get into the threads if you can reach the back side.
I've also found clutch head screwdrivers and bits at Ace hardware.
07-14-2014, 01:08 PM | #10 |
Re: those screws
If there is room you can weld a nut to the head and use a socket to remove some of them .
07-14-2014, 01:27 PM | #11 |
Re: those screws
Also, if they have been painted over it helps to take a pick and clean out the slot so that the bit gets a full bite. It keeps them from stripping out. I replaced most of mine with either hex or button head allen screws.
07-14-2014, 05:42 PM | #12 | |
Re: those screws
+ one . were ever i can i swap out with SS phillip...Sp
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
07-14-2014, 05:53 PM | #13 |
Re: those screws
The first tool I ever bought of the SnapOn truck (MANY more to follow) in 1977-78 so I could properly remove the screws from my truck.
I don't know what problem would cause them to round out, they are pretty much one of the best ever for NOT rounding. If the screw is clean and it's the right size tip, it WILL turn that screw in my experience. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
07-14-2014, 07:10 PM | #14 |
Re: those screws
ironic, that was my first snap on purchase too, in 1970
my second was a blue point hammer impact to remove phillips head screws from yamaha motorcycle cases and my 3rd was a clutch head bit to put on the impact driver to remove the fender bolts off my 58 for clutch head screws like what holds the trans cover on i use a flat head screwdriver for fender bolts... torch or grinder
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-15-2014, 05:09 AM | #15 |
Re: those screws
I just ground an old standard screwdriver down to fit. worked fine.
07-15-2014, 07:08 AM | #16 |
Re: those screws
Amazingly took my 55 1st apart 2 years ago without penetrating oil and broke ONLY 1 bolt. Total frameoff
07-15-2014, 09:12 AM | #17 | |
Re: those screws
I still have all my Snap On purchases from all those years ago. This is one of the reasons I preach to buy good tools, not only do they last, I could sell them for MORE than I paid for them! Brian
07-15-2014, 01:27 PM | #18 |
Re: those screws
Not to hijack, but we need to start an "Old tools that we love" thread. I have lots of them.
07-19-2014, 03:07 AM | #19 |
Re: those screws
welding nuts on works well!
07-19-2014, 10:54 AM | #20 |
Re: those screws
As a last restort to remove a broken stud or a rounded off screw or bolt yep welding a nut to it has been done many times by this guy.
Brian
07-19-2014, 10:10 PM | #21 | |
Re: those screws
I used to use a regular screwdriver but after rounding several I just went ahead and bought the proper socket drivers.
On this end of the country the answer usually looks like this: |
