Old 07-14-2014, 11:03 AM   #1
jackyl9999
jackyl9999's Avatar
Return Line Question/Issue
I am plumbing my fuel system for my 6.0 swap into my 70 GMC. I am using the stock in cab tank. I added a 2nd line to my sending unit and when I was trying to get the sending unit into the tank, the return line tube broke off at the weld. The tube was equal length to the pickup tube. Now it is flush. The return line is still solid as a rock.
Can I use this and not have any negative effects? I would think the only issue would be hearing the gas returning into the tank?
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 07-15-2014, 01:57 AM   #2
Gobuffalo
Gobuffalo's Avatar
Re: Return Line Question/Issue
When the tank gets part way empty, your going to have a lot of fumes. Vapor ignites easier than liquid. If you have an in tank pump it may starve for fuel when you are low.
Gobuffalo is offline   Reply With Quote
Old 07-15-2014, 12:52 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
FWIW, I'm running an external pump, so I don't have an internal tubes or anything for the return...its just a fitting at the top of my tank that pee's the returned fuel back into the tank.
You won't starve the pump as long as the pickup tube itself is still fine (and you have it at the lowest point)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-16-2014, 01:41 AM   #4
jackyl9999
jackyl9999's Avatar
Ok. I should be good then.
Thanks Brew City
1990 K1500 Daily
