A/C Bracket help
I've been searching for anything to help me figure out how to install the compressor I just bought.
![]() Are these brackets for a different motor? |
Re: A/C Bracket help
Definitely later than '72. Long water pump design and the condenser lines exit the wrong side.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
well, once I figure out where these came from I might have a set of compressor brackets and a condenser available...
Old member
I think they are off a full size car of the same years. 70-80 models.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
One of the limiting factors on the condenser size is the way the hood latch brackets, both at the top and the bottom, limit the height of the condenser. The condenser you have is much taller than will fit a 72 truck.
Thanks, this new condenser is definitely too big.
Old member
Here are the correct brackets for a small block Chevy truck AC. I sold this set a while back.
