07-14-2014, 04:42 PM | #1 |
wheels
So I like the wheels from the early 2000 trucks and I think it would look better than the rusting steel wheels I have. So my question is will the early 2000 truck wheels fit on my 70 c10. I do have the 6 bolt lug pattern. Thanks for the help
07-14-2014, 06:56 PM | #2 |
Re: wheels
i think they went to a metric pattern, but do not quote me
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
07-14-2014, 07:14 PM | #3 |
Re: wheels
Same pattern!
6x139.7 or 6x5.5 for you south of the 49th. However you need to be aware of the offset or backspace and the hub bore size. |
07-23-2014, 09:05 PM | #4 |
Re: wheels
So what will I need to do to correct the issue with the hub bore size
70 C10 with in line 6 for now and 3 speed moved to the floor 94 K2500 currently in motor upgrade |
