What 5 lug rear axle do you guys think
I am wanting to change the rear end in my 67 to 5 lug instead of 6. What years will interchange without too much modifaction?
Re: What 5 lug rear axle do you guys think
I would say the easy way would be to just change the axles. they make a axle to change from the 6 to the 5 lug I think Moser has them
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
67-69 and some 70 model differentials are about 1/2" shorter per side compared to the 71-72 5 lug differentials. I know from experience as I am going through the same conversion.
You can buy conversion axles from some suppliers. These would be the shorter, correct length for your differential tubes, and they would be 5 lug. You can have your 6 lug axles welded up and re-drilled to 5 lug. You can have 5 lug axles shortened to the 6 lug axle length and re-splined. All these options require you to buy the correct drums, etc. Or, you can buy a 71-72 rear end with all of the correct axles, brakes, etc., and have it rebuilt and painted. You might even be able to select your drive ratio, or even put a posi chunk in it. I am going the whole rear end route as I can buy it rebuilt, rebuild the brakes, and do the swap in a day. Your mileage may vary. |
redrill your axles !!
![]() Join Date: Oct 2013
Has anyone redrilled your axles?Do they have to have the old holes welded?I have to do the same thing with my 68 thanks Oz
had mine redrilled and it was done good
I am also interested in redrill info. I am torn right now between 5 and 6 lug conversion. I have all new front end disk brake parts, but they are 5 lug. So either I buy new rotors, or I redrill rears. I'm leaning toward redrilling because I want to run some 5 spoke rally rims or cragars.
There is a local shop here in Sacramento called Jaws Gear and Axle' they have 5 lug conversion axles for $130 each. Most places I have seen are double that
http://www.jawsgear.com/Axle_Shafts-Chevy-Truck/ |
I bought my Moser 5 lug axles for around $260 from Summit w/ free shipping. The swap only took about 1 hour and most of that was scraping the old gasket off the differential cover!
![]() Join Date: Nov 2007
67-72 parts collector,…
![]() Join Date: Nov 2002
Buy new axles.
Doing a 5-lug conversion on my '70 C10 as well. For the rear, i just need axles and drums? All the brake hardware the same '70-'71?
#13 |
Really confused here, I have the wide rear end that came in the '70 C10, if I get the 5 lug conversion axles, would i technically have a '71-'72 rear end? any help shedding some light on this would be great. I'm trying to get everything ordered for the conversion/drop, don't want to miss anything.
#14 |
The $130 axles in the above site are now $185
#15 | |||
"I ain't nobody, dork."
If you ordered stock style 1971-72 axles with 5 lugs, they would be the wrong length for your 1967. Clear as mud? Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#16 | |
Posted via Mobile Device |
#17 |
Looks good at 20-ft .....
We used the rear end out of the (75 - 76 ?) suburban which was the donor for my engine & trans.
Easy install & instant 5 lugs matching the whole front end swapped out of same vehicle. |
