07-14-2014, 11:30 PM | #1 |
L99 fuel pressure ?
Anyone know if the fuel pressure on a 2012, 6.2 (L99) needs to be the same as other LS based engines?
Will the Corvette fuel filter achieve the correct pressure for this motor like it does for other LS series engines?
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
07-15-2014, 12:19 AM | #2 |
meowMEOWmeowMEOW
Re: L99 fuel pressure ?
as far as I'm aware, the rail pressure for all the LS motors is the same, barring the flex fuel engines (~58psi vs ~42)
07-15-2014, 10:53 PM | #3 |
Thanks.
Anybody else?
07-16-2014, 11:33 AM | #4 | |
The Corvette filter/regulator output is 58 psi. |
07-16-2014, 04:31 PM | #5 |
58 PSI. You have to get the correct Corvette FPR, there's a 42 PSI (LS1 3 bar) and a 58 PSI (LS2 + 4 bar)...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-16-2014, 09:57 PM | #6 |
Thanks for the help guys
07-17-2014, 12:31 AM | #7 |
Hi painter D, I cleaned the injectors on my co-workers 5.3 in a 2009 1/2 ton 4x4 pickup. I monitored fuel pressure before i hooked up my injector cleaning machine and this is what i found; cold start up about 60 psi, and once warmed up at curb idle it was about 42 psi. I believe this is a pulse width modulated (PWM) fuel pump system. engineers went to this system to extend fuel pump life with less load at times. Case in point is this: Going downhill, throttle closed, injectors will shut off (called decel enleanment) and there is no need for fuel pressure at this time so why deadhead the pump, just shut it off. The spec i read if remembered correctly was PWM pumps last twice as long as non-PWM fuel pumps. This co-workers truck did not have an external filter anywhere as i believe it is internal in the tank and i call it a basket style. I see a lot of projects use hptuners, efi live, etc for programming, but if it was me i would use what gm did and benefit from their hard work. Aftermarket parts and programming has done wonders for all of this, i just feel that a lot of times the oem stuff gets overlooked and never considered. Good luck, Brian Fuller
07-17-2014, 03:24 AM | #8 | |
meowMEOWmeowMEOW
All the people I know who work for GM or supporting companies, use either HPT or EfiL to tune their own cars and projects. As an example, the defueling "feature" you mention is great for stock uses, however it can be dangerous to a performance vehicle. If you go WOT and have to rapidly lift, you put the engine into that condition (0 throttle decel) and shut the injectors off, you lose the cooling effect that the fuel has on the engine in said condition. Going lean in that condition is normal, but that can be a dangerous lean. Yes GM did a lot of engineering and did some great stuff with it, but the aftermarket has put tons of specialty r&d into things as well, finding solutions to fill the gap that GM left.
