Old 07-15-2014, 01:22 AM   #1
Thumper169
Porterbuilt Dropmember On a Longbed
I'm trying to find out if a Porterbuilt rear dropmember will fit a longbed 71 C10with a 2 piece drive shaft?? and I cant get a response from them directly. It apprears everything is the same as the short bed but Id like to confirm the fitment if I can. It's also currently running a leaf spring suspension so I assmume a new set of spring perch's would be needed as well or does the kit come with them? and running a 8.5" rear wheel would I need inboard or outboard bag mounts? Truly sorry for asking such dumb questions but after weeks of trying I cant get these answers and I want to get the parts ordered asap.
Thumper169 is offline   Reply With Quote
Old 07-15-2014, 01:34 AM   #2
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Porterbuilt Dropmember On a Longbed
Yes you can run the dropmember on a long bed chassis.. Perches will be needed if your run the trailing arm setup.. Or you will not need them if you do a 4 link setup.. You can safely run up to a 10" wide wheel on a outboard bag setup.. If you need any help with parts from porterbuilt let me know how I can help my shop is authorized dealers for porterbuilt..
Kyle
405-243-7626
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 07-15-2014, 08:47 AM   #3
Pro Performance
Pro Performance's Avatar
You can run up to a 12" wide rear wheel with an outboard bag setup. It is a tight fit, but with the right backspace, it can be done.
Pro Performance is offline   Reply With Quote
Old 09-17-2014, 02:23 PM   #4
71CRBURB
Have any pictures and/or details about this? Thanks
71CRBURB is offline   Reply With Quote
Old 09-17-2014, 03:11 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
Typically when running a 12" wide wheel we go with the inboard bag/outboard shock set-up.
Space is just at a premium with the 12. Get's really tight at the upper bag mount on the outboard bridge.
Here's a pic of when we mocked up an inboard bag/outboard shock set-up.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-17-2014, 07:41 PM   #6
Pro Performance
Here is a picture of the chassis for the '63 we are building. While this is not the prime example, it is a good one, and will serve the purpose. Not the best angle, but will give an idea.
This wheel and tire combo measures 12" overall, so this is about 1"-1.25" narrower than what a 12" wide wheel will measure with a tire on it. The actual tire size will vary the overall width of the 12" wheel / tire setup. Assuming you go with a 335, your overall width will be around 13.125" wide.
With all that said, this is the narrower axle, with a wheel backspace setup for a wider axle. This means the wheel and tire in the picture below is sitting .75" closer to the frame than it normally would. Right there we would gain .75" of room with this setup, having the right backspace on the wheel. Now, to account for the other .375" of width, we would come in a little, and also push it a little more to the outside.
As mentioned, it is a tight fit, but can be done with outboard bags. Of course, inboard bags would make it easier and give you a little more breathing room.
Hope this info helps....
