Old 08-06-2003, 01:10 AM   #1
Sammy
Brake Bleeding & Slotted Rotors
Curious if anyone has tried EARLY CLASSICS speed bleeders...ITEM # 5B51624/ 5B3824..The design claims that it has a check valve you open the bleeder. then you just step on the brakes the valve open allows the air to bleed out when you allow the pedal to return the check valve prevents additional air in the system....
....Also Slotted disc's do they or cross slotted offer any benefits?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-07-2003, 01:43 AM   #2
Low68
Low68's Avatar
I haven't tried the bleeders, but crossdrilled rotors are supposed to help cool the rotor. I am not really sure what slotted rotors do. Probably something like that.
Low68
Build Thread
Low68 is offline   Reply With Quote
Old 08-07-2003, 06:08 AM   #3
68 Suburban
68 Suburban's Avatar
Slotted roters help the hot gasses excape, so you don't have brake fade.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-07-2003, 09:56 AM   #4
slam33
slam33's Avatar
I tried some speed bleeders from NAPA, they did not work at all. They wouldn't seat right and bleed past the threads. As for the rotors, even though you don't really need the slots or crossdrilling becuse your not going to be on them every minute so there really not going to get race car hot, they are cool and you might cut a few feet off you 100 to 0 distance.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 08-07-2003, 10:48 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
All it takes is ONE friend to help you bleed your brakes....
I don't trust anything short of an eyeball to know for sure that nothing is coming out except brake fluid. Start at the wheel that is farthest away from the master cylinder (right rear, if your steering wheel is on the left), and work your way to the left front.
I like the looks of the slotted and cross-drilled rotors, although I think the cross-drilled look better. It's just money....of which I don't have nearly enough.
Member Nr. 2770
Old 08-07-2003, 03:53 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Personally, i let my brakes gravity bleed. Some times they will need a kick to get started, but that is only once out of 10 times. I never believed it untill I started doing it every day.
As for the rotors, I can't speak for the slotted ones, but the cross drilled ones like to crack by the holes.
