Looking for a pitman arm nut.
Looking for the nut that attaches the pitman arm to the steering gear box. Thanks
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
Re: Looking for a pitman arm nut.
Ok lets try this where will I find one?
![]() Join Date: Sep 2007
So not the castle nut but the big one that attatches the arm to the gear itself right? Ill betcha specialty retail has one. Hit him up
1967custom |
Correct thank you for your reply I had no luck at the local parts stores. I will give it a try
![]() Join Date: Dec 2013
check your local junk yard !
Up to what year did they use the same size nut?
![]() Join Date: Jul 2007
I should have one. I am in new river.
likely up to 1978 when they converted to metric on the steering gear
1967custom |
Di you still need one? I found the nut and lock washer if you do
1967custom |
