Old 07-15-2014, 11:51 AM   #1
Bigdav160
Bigdav160's Avatar
Rust Mystery
My Suburban came out of southern California but, from the story I got from the previous owner, it spent a lot of time down in Baja.
So my rust problems aren't the ordinary ones.
So I'm curious what caused this rust on the inside. The fender well area looks pretty clean. What the heck was that hole used for? This is on both sides.
I'm not sure what attempts I should make to address it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 07-18-2014, 04:44 AM   #2
Cobalt964ruf
Cobalt964ruf's Avatar
Re: Rust Mystery
hey dav, take a piece of cardboard, size it up to that panel with some scissors. make it as close to the entire panel you have there in the pic. then use the cardboard as a template on some new sheetmetal. then cut out the rusted panel, trim in the new steel and weld it up. I can get into more detail if you wish. have fun dav.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 07-20-2014, 08:15 AM   #3
Franks 72
Franks 72's Avatar
Re: Rust Mystery
Our truck had a similar problem (Canadian winters / road salt) . The patch repair worked well to keep out road dust and water however it masked the underlying decay.I chose to remove the entire crossmember which is at the transition from floor pan to plywood.This was nessesary to get at the rust in the vertical inner body panels which will need to be replaced. Your inner body panels dont look to bad but it is hard to se behind where he crossmember is bolted on.Check it carefully in this area. I have included a picture of the rust damage / patch.
Removing the crossmember is a huge job (spot welded / welded to floor pan) and I would not suggest it unless you have major rust issues. I would be interested if anyone has ever fabricated the inner body pieces since I will need to do this. Hope this helps.
Franks 72 is offline   Reply With Quote
Old 07-20-2014, 12:01 PM   #4
Cobalt964ruf
Re: Rust Mystery
Rust always has a larger surface area than visually seen.
Old 08-07-2014, 12:01 PM   #5
GuyO
GuyO's Avatar
Re: Rust Mystery
It sucks but where there is water and oxygen, theres rust. And like Frank says, just add salt and the sodium chloride makes it worse especially if the water can't get out like where your area is. Personally, I do not think there are enough drain holes in Burbs or Blazers. Even with Pickups, the fender and door drains are too small and get plugged with dirt or spray on undercoatings. I too would cut it out and weld in a new piece but be careful welding a galvanized patch, heating the zinc becomes a poisonous fume. I have tried a lot of things for rust removal and rust treatment including electrolysis using laundry soda, muriatic acid dips and occillic acid dips for parts. But for body grinding/brushing/neutralizing and patch panels! Good luck, love Burbs! G.
GuyO is offline   Reply With Quote
Old 08-07-2014, 02:40 PM   #6
franken
Re: Rust Mystery
No mystery. There was no paint applied to boxed areas, or even hard to reach unboxed areas. So as seen in the pic, the rust comes from inside and you wind up with a painted surface that has almost nothing but rust behind it.
In the mid to late 70's they started using more galvanized metal, and dipping the bodies in primer. This improved things a lot.
franken is offline   Reply With Quote
