Old 07-15-2014, 03:08 PM   #1
Hugh Mongus
Quick, Easy question (Hopefully)
I have been searching the forum and the web for this information, and I cannot find a definitive answer...
What temp sender can I use in vortec heads that is compatible with the factory temp gauge? I have seen talk about a machinist reducing the size of the factory sender, certain senders working at various temps but not all temps, and others trying different senders from Napa, but nothing that says "THIS ONE WORKS".
Can someone post a part number of a known working sender for vortec heads?
Thanks!!
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 07-15-2014, 04:31 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Quick, Easy question (Hopefully)
Below is a link to the latest thread about this. Simply stated, you can use an original sensor by have it machined for $20 or drill and tap the head. Forum member brian mac can machine your sensor. His contact info is in post 23.
http://67-72chevytrucks.com/vboard/s...d.php?t=627880
FirstOwner69 is offline   Reply With Quote
Old 07-16-2014, 09:06 AM   #3
Hugh Mongus
Thanks!
-Jason
USN Retired
Old 07-16-2014, 10:36 AM   #4
joeydurango
joeydurango's Avatar
Or you can buy a cheap brass Autometer adapter that will take your original sender and allow it to be used with the Vortec. That's how mine's set up, and it works great. The only thing is that the needle on the temp gauge isn't in the middle when it's at operating temp - but once you know what normal is, it's no problem. Sorry, it's been a while since I bought that adapter, so no part number - but they're under $15 and readily available. Just a metric thread -> NPT adapter, a very basic part.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 07-16-2014, 01:12 PM   #5
davepl
davepl's Avatar
I've drilled and tapped an intake manifold for the original temp sensor. The big fat tap itself wasn't cheap ($35 I think) but it wasn't rocket science. It is a tapered thread so I'd check your depth with the sensor periodically as you tap it.
That said, I have no idea if drilling into the head is a good idea. Only ever done it on an intake.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-16-2014, 02:36 PM   #6
jocko
jocko's Avatar
I highly recommend Brian Mac. Solved my problem with factory results. I don't recall the original gauge reading to be centered at operating temperature, but i could be wrong. Joey's approach would be great also - Joey, any part numbers or info on that adapter?? Thanks for sharin that. Anyway, I used the standard "TU5" sender and Brian resized it for me. Works perfect.
