Old 07-15-2014, 04:16 PM   #1
joey8383
joey8383's Avatar
Should I replace this or heat it and straighten? (Trailing arm bracket)
After picking my frame up from the sand blaster, I noticed this bracket bent (see pic). I suspect his forklift hit it. So my question-- Should I heat it and straighten it or cut the rivets off of both of them and use bolts to bolt both of them back on to have them matching? If so, what size bolt do you think will hold up in this spot??
joey8383 is offline   Reply With Quote
Old 07-15-2014, 04:27 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Should I replace this or heat it and straighten? (Trailing arm bracket)
Heat and bend not a critical bracket , save your money and continue on . just make sure it's close and your panhard bar will do the rest !
Grumpy old man is offline   Reply With Quote
Old 07-15-2014, 05:23 PM   #3
67swb72klb
67swb72klb's Avatar
I would try a BIG crescent wrench first with out heat and see how it goes
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 07-15-2014, 05:24 PM   #4
joey8383
joey8383's Avatar
OK. I have a parts truck that I can go rob one off of so it would just be a couple hours of labor to break down the suspension on parts truck.
Old 07-15-2014, 07:29 PM   #5
litew8
litew8's Avatar
x3 for bending it back.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 07-15-2014, 07:50 PM   #6
71swb4x4
71swb4x4's Avatar
I would put masking tape on it, and then use a big crescent wrench like 67 above mentioned. You can probably get it bent back and save the paint.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-15-2014, 08:05 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Big crescent wrench will do the trick. However I do not think you will save the paint.. Too much bend... WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-15-2014, 08:09 PM   #8
joey8383
joey8383's Avatar
I will try to just bend it back. Thanks guys. I just painted it because it was trying to rust over night. I can touch it up when I paint the rear end and other small parts.
Old 07-15-2014, 08:15 PM   #9
litew8
litew8's Avatar
Try putting a rag over it and bend. There might be a chance the paint stays. A crescent wrench might fit, or a large pair of vice grips. If it doesn't turn out like you'd like, you've always got the spare from the other truck.
Old 07-16-2014, 06:47 AM   #10
hamjet
hamjet's Avatar
boy, if you look at the top of the frame where the bracket is riveted, it seems to be bent also, is that a factory bend? That would really tick me off... But I would also straighten it..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 07-16-2014, 06:56 AM   #11
CUSTOM/10
CUSTOM/10's Avatar
hamjet
I believe what your seeing on the frame is factory, the bend is in the wrong direction for it to have happened when the bracket got bent !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-16-2014, 01:08 PM   #12
71swb4x4
71swb4x4's Avatar
That's the crossmember, not the frame.
