Old 07-15-2014, 08:21 PM   #1
rustbelt
rustbelt's Avatar
Need advice on positioning of rearend
What are the steps needed to correctly position or 'track' the replacement rear end in my 61 Step side? I'm dealing with trailing arms and coil springs so positioning correctly using the U Bolts is easy, but aside from the way it will sit after the drive shaft is connected, is there anything else to look for on the left to right positioning?
rustbelt is offline   Reply With Quote
Old 07-16-2014, 12:30 AM   #2
Captainfab
60-66 Nut
Re: Need advice on positioning of rearend
I would make sure that the trailing arm mounts are the same distance from the backing plate on both sides. If you go with an adjustable panhard bar, you can fine tune the tracking of the rear differential. Also you will have to get the pinion angle correct. Otherwise you will have a vibration and if it is too far off, you will go thru u-joints.
Old 07-16-2014, 12:47 AM   #3
jtrichard
this may help http://67-72chevytrucks.com/vboard/s...d.php?t=624445
jtrichard is offline   Reply With Quote
Old 07-16-2014, 06:30 AM   #4
rustbelt
rustbelt's Avatar
Thanks guys for the responses, they were very helpful. In regards to getting the correct pinion angle, since I've not welded the axle mounts to the rear end yet, I was thinking that rotating the snout so that the pinion yoke was in straight line with the drive shaft would insure I'm at the correct angle. Would this be sufficient?
Old 07-16-2014, 11:45 AM   #5
PGSigns
PGSigns's Avatar
You need to do more than that on setting the pinion angle. The way you are planning wont work. There are some threads here that go into it in great detail. The linked thread above is one way to do it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
