Old 07-15-2014, 10:50 PM   #1
Dubnova
LS Transmission Help?
Hey guys, I am starting the process of installing a LS (5.3 or 6.3) into my 65. I was wondering what transmission will fit without cutting up the floor in a LOW hump truck. I will have a CPP 5/7 static drop if that matters and I am using the CPP LS swap kit. Thanks.....
Dubnova is offline   Reply With Quote
Old 07-16-2014, 12:08 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS Transmission Help?
There is no 6.3.
Is this a 47 or a 77 were talkin about? Are you looking for an auto or manual trans? Give us something to work with here
The 4l60e is the smallest you'll get w/ the motor, and it fits into most swaps without much clearance issues. It takes up the same space as the 700r4, and only a little more than the th350, just longer.
The th400 has a fatter case, as does the 4l80e which is also longer. The 4l80e is another trans commonly found behind the ls engines. Its beefier, but weighs more and uses more power. I have one in my 66, and at least for the 60's trucks, it fits without having to modify the tunnel.
Manual trans folks use the m22, the t5, t56, it all depends.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-16-2014, 07:56 AM   #3
Dubnova
BR3W CITY, Thanks for the reply. I meant to say automatic transmission. The LS3 6.2 is what I am leaning towards and I want the strongest trans I can get without having to cut up the floor. The 6l90e looks like it came out of a dump truck and I'm sure that it will require a lot of cutting. My 65 C10 is really clean with good floor pans (34000 miles) so I kinda don't want to mess with the floors but, I will if I have to I have a T56 Mag in my Nova and I can tell you it's the best manual trans I have ever shifted.
Old 07-16-2014, 09:38 AM   #4
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Both 6L80 and 6L90 will require a high hump... I have test fitted both...
I think 4L80 is the biggest/strongest with low hump but others may need to chime in and I haven't done this test fit myself yet
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 07-16-2014, 01:35 PM   #5
66LSx
66LSx's Avatar
5.3L / 4L60e was no problem in my 66 low hump
It's (4L60e) also the weakest so if your planning high HP application... skip it and go 4L80e or 6L80e
My 5.3L is just going to be a cam/exhaust daily driver... 4L60e fits the bill as I probably won't have a rear tire wide enough to ruin the trans. (get traction)
Also a dime/dozen to find/replace if/when I grenade it
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-16-2014, 10:09 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: LS Transmission Help?
I put the 6.0 and 4L80E in my 71 with small hump with no problems at all. Couldn't ask for a better street combo.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-31-2014, 10:41 PM   #7
GVDobler
GVDobler's Avatar
Anyone know the difference between a 4x4 and 2wd 4l60e ?
I know the 4x4 is shorter, but by how much?
If I have to shorten my drive shaft anyway, would it matter which I use in a '66 Suburban?
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 08-01-2014, 01:48 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not for the 60e, that assumption applies to the 80e, in which the physical case is about 3" shorter.
On a 4l60e or 700r4, the length should be the same, but its the tailshaft sections that are different.
Fwiw, TCI has diagrams of most of them.
http://www.tciauto.com/tc/trans-dim/#4L60Elate
