Old 07-16-2014, 02:19 PM   #1
ACII
A/C swap ???
Hy all
i probably get a complete camaro z28 from 1999....for doing an LS1 swap into my 51 chevy pickup
for saving money , i am thinkig about swapping the Air Conditioning as well.
Has anybody already done this ??
I would like to swap all the needed parts ... is this possible ?
Achim
ACII is offline   Reply With Quote
Old 07-16-2014, 09:43 PM   #2
Iceburgh
Iceburgh's Avatar
Re: A/C swap ???
If you are trying to stay in between the stock frame rails with stock suspension or MustangII you have very few option. If it is a sub frame swap no problem
Using the stock set up is not one of them.
I tried every way. A few options.
1. Mount it high with brackets available. It hangs 17" to the passenger side and the inner fender will need cut
2. Mount low on drivers side and put a SERIOUS notch in the frame/cross member
3. Buy one of the few compact units on the market $$$
4. Roll the windows down
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 07-17-2014, 12:38 PM   #3
ACII
Re: A/C swap ???
Hy
my pickup does have a camaro subframe....
So i can just swap all the parts like..... ??
Condenser
Drier
evaporator
e.g....
Achim
Old 07-17-2014, 07:15 PM   #4
Iceburgh
Iceburgh's Avatar
Re: A/C swap ???
yes it should all fit inside a subframe
1953 suburban build
