Old 07-16-2014, 03:52 PM   #1
bigmac73
bigmac73's Avatar
gasket wrinklel
I got my front windshield put in today, I have a few wrinkles in each of the upper corners, other than that it looks good, original trim installed and still in good shape,
and before anybody says anything yes i used a Precision gasket from GMC Pauls, and a original OEM front windshield I cut out of an rotted truck in a field
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-19-2014, 06:50 PM   #2
bigmac73
bigmac73's Avatar
Re: gasket wrinklel
here are a couple of crappy pics of top corners , do not mind the cut out holes in cab(rust removal)
Mike
Old 07-19-2014, 08:30 PM   #3
Lee H
Lee H's Avatar
Re: gasket wrinklel
I have never seen an after market installation that the gasket did not wrinkle a little. It's all good.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-19-2014, 08:42 PM   #4
tommys72
tommys72's Avatar
Re: gasket wrinklel
Mine is aftermarket now, and did the same thing...same spots
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 07-19-2014, 09:39 PM   #5
diggerbob
diggerbob's Avatar
Re: gasket wrinklel
mine looks like that...it leaks when I drive in the rain
diggerbob is offline   Reply With Quote
Old 07-20-2014, 12:05 AM   #6
WIDESIDE72
WIDESIDE72's Avatar
Re: gasket wrinklel
Im curious as to why you didnt go ahead and weld in patch pieces for the area above the windshield before the ws install. Will you have to pull the ws to weld the pieces in?
WIDESIDE72 is offline   Reply With Quote
Old 07-20-2014, 08:37 AM   #7
sboris
sboris's Avatar
Re: gasket wrinklel
That's what I was wondering.. If it were a finished truck, I would have it redone.
good luck
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 07-20-2014, 03:17 PM   #8
bigmac73
bigmac73's Avatar
Re: gasket wrinklel
money and time, the whole cab needs to come off for the sheet metal work, I have a whole new floor to install and rockers and cab corners plus the spots above the windshield.
sometimes i realize that i am doing somethings backwards, but when you drive your truck most of the days of the week, I do what i can when i can do it,
Plus the old W/S was cracked and leaking bad at the bottom R corner
Mike
