Old 07-16-2014, 04:38 PM   #1
Ocho702
LS swap engine mounts
What are some good engine mounts for a 1967 gmc truck that will have a 5.3 LS engine?
Ocho702 is offline   Reply With Quote
Old 07-16-2014, 04:41 PM   #2
chasinhiway
chasinhiway's Avatar
Re: LS swap engine mounts
I used dirty dingo and really like them. You can find tons of info in the LS swap section.
LOWER IT AND DRIVE IT
Sally's thread http://67-72chevytrucks.com/vboard/s...d.php?t=563266
chasinhiway is offline   Reply With Quote
Old 07-17-2014, 10:02 AM   #3
kamikazekyle05
kamikazekyle05's Avatar
im using ece on mine
kamikazekyle05 is offline   Reply With Quote
Old 07-17-2014, 10:09 AM   #4
truckdude239
truckdude239's Avatar
I used dirty dingo mounts and the stock engine mount http://dirtydingo.com/store/index.ph...5_322&CDpath=8
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-17-2014, 11:20 AM   #5
Matt Cramer
I cut a set out of 1/4" steel strip with a chop saw and drill press. Details here:
http://www.diyautotune.com/tech_arti...t_adapters.htm
I've put up a set of downloadable PDF templates if you want to copy them. Note that the version I used required cutting and welding the stock frame stands, a trade-off to allow using a stock A/C compressor down the road.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
