Old 07-16-2014, 09:21 PM   #1
Jimbo0076
Jimbo0076's Avatar
DRW to SRW Questionnaire
Working on a '96 C3500 crew cab long box that is my newer acquired turd to my fleet Long story but I'm looking into possibly converting this dually into a single rear wheel truck. I know most all the basics behind all this and mostly asking to reassure myself. The truck has 3" Belltech drop spindles and from what I've found the spindle is the same for a single wheel and dual wheel truck. Also looking into my catalogs(I sell auto parts for a living) it looks like the bearings are the same ID for the spindle on single and dual truck. Other than the brake rotor wheel mounting surface they are very similar.
So can a simple rotor swap make the truck into a single wheel?
On the rear I know the dually 14 bolt is narrower than SRW. Mainly wondering if the spring plate width is the same on a DRW and SRW 14 bolts. My truck currently has 4.10s and I'd love some higher gearing to be able to stretch its legs some more than 65mph @ 3200rpm on the old big block.
Can a 14 bolt(preferred full floater) SRW be bolted right back in place of the DRW?
Thanks a lot fellas
Jimbo0076 is offline   Reply With Quote
Old 09-15-2014, 04:29 PM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: DRW to SRW Questionnaire
x2 on the same questions but mine is a 95 K3500 DRW.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 09-15-2014, 05:22 PM   #3
teamroper!
teamroper!'s Avatar
If it were mine, I'd look for a ff rearend out from under a 2001 up 2500hd with disc brakes
teamroper! is offline   Reply With Quote
Old 09-16-2014, 08:15 AM   #4
BigBlocksRule
Should work, the 4WD's use a spacer for front on a dually setup.
Since both use the same frame and connection points, I don't know why the rear end shouldn't be a bolt-up deal.
BigBlocksRule is offline   Reply With Quote
Old 09-16-2014, 08:23 AM   #5
95 S_Trucker
95 S_Trucker's Avatar
2wd- get SRW front rotors
4wd, un bolt DRW adapter from hub
Both, Get SRW Rear Axle, as long as its from the same era truck(88-00) it will bolt right in
95 S_Trucker is offline   Reply With Quote
Old 09-16-2014, 08:25 AM   #6
BigBlocksRule
You need to do a bit other than unbolting the spacers from a 4WD, although the bolts are same size and pitch, they're not lug bolts. Easy to swap out with a press, though.
