Old 07-16-2014, 10:51 PM   #1
70CHEVYBB
70CHEVYBB's Avatar
eaton rear end / need advice
I have a 70 3/4 ton with a eaton rear end. I pulled the cover discovered its not a posi. I could not find numbers on the ring gear but counted 41 teeth. so Im sure its a 4:10. I was really hoping for a posi. What options are out the make it a posi if I even can??
Thanks, Wes
70CHEVYBB is offline   Reply With Quote
Old 07-17-2014, 12:10 AM   #2
SS Tim
SS Tim's Avatar
Re: eaton rear end / need advice
So what made you hope it was a posi, SPID, codes or a sticker?
The Eaton H052 was available with a NoSpin locker from the factory (SPID code G86) or dealer installed. On an H052/72 the NoSpin replaces the spiders inside the existing case. Did you actually see spider gears?
Unfortunately the NoSpins are kind of hard to find and bring a fair amount of money. However a 14 bolt Detroit Locker can apparently be used if the axles are replaced (there is a spline count difference between the two axles). A quick site search should get you to an interchange thread for specifics.
41-10T would be a factory 4.10 ratio
SS Tim is offline   Reply With Quote
Old 07-17-2014, 12:15 AM   #3
bluek5
bluek5's Avatar
Not sure about the the spline count. There is a new 19 spline on ebay for $500.00. You may want to pay the $25.00 and subscribe. Then post a want to buy thread. I have found two at the pick-n-pull in the last couple of months. Hope this helps.
Paul
bluek5 is offline   Reply With Quote
Old 07-17-2014, 12:18 AM   #4
bluek5
bluek5's Avatar
After looking at the picture SS Tim posted, I am pretty sure the one I posted isn't correct.
