Old 07-17-2014, 11:30 AM   #1
76er
Aftermarket Subframe
Hello all haven't been on in a while, to busy. A few months ago found a link about a company that sells a subframe that replaces exsisting front clip that once welded on accepts gm g body suspension components. It's made for TF trucks and some mid fifties gm cars but I can't seem to remember where was. Has anybody seen this or know the name of the company. Ready to buy. Thanks in advance for any help
76er is offline   Reply With Quote
Old 07-17-2014, 03:56 PM   #2
nvrdone
Re: Aftermarket Subframe
Check Jim Meyer Racing in Portland OR
nvrdone is offline   Reply With Quote
Old 07-17-2014, 06:27 PM   #3
76er
Great site with lots of goodies but that's not it, they only make them for cars and you have to buy all the components from them. The one I was looking for you just buy the subframe and get the suspension pieces from your local salvage yard. thanks friend
Old 07-18-2014, 08:48 AM   #4
68GMCCamperSpecial
Check Fatman Fabrication in Charlotte.
68GMCCamperSpecial is offline   Reply With Quote
Old 07-18-2014, 10:02 AM   #5
Scottshotrods
Take a look at what we have to offer at www.scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 07-18-2014, 10:38 AM   #6
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I don't think it s made anymore. There is a board member here that has it under his truck, its white, but don't remember his screen name.
ChuckDriver is offline   Reply With Quote
Old 07-18-2014, 11:04 AM   #7
starterman99
starterman99's Avatar
Scott Danforth IFS
I looked in to this when I was starting my truck.Google it or theres a thread here
http://67-72chevytrucks.com/vboard/s...d.php?t=383312
1950 5 window
starterman99 is offline   Reply With Quote
Old 07-18-2014, 12:19 PM   #8
ChuckDriver
Originally Posted by starterman99 View Post
Scott Danforth IFS
That's adapting the C-10 suspension to a TF truck, I don't thinks that what he is looking for.
Old 07-18-2014, 12:20 PM   #9
ChuckDriver
Here's the link to the thread with the bolt in, its actually a bolt in clip that uses the G-body components.
http://67-72chevytrucks.com/vboard/s...d.php?t=489721
Old 07-18-2014, 02:15 PM   #10
mr48chev
mr48chev's Avatar
It looks like he built his own subframe though as there is no mention of who it came from butb he did say that he 'assembled it on a table".
I think I saw an article in one of the truck rags about the subframe in question but don't recall a thing about it more than that. I'm not even sure what components were used on it.
Scott turns out a great product if it fits in your budget. Danforth's crossmember using the C10 components is also gaining favor with more guys who like the idea of having truck pieces in a truck. Steve at Industrial Chassis in Phoenix will build you a front end using Dodge Dakota components or his own fabricated pieces http://www.industrialchassisinc.com/ I'd think his prices compare with Scott's pretty much straight across.
Personally I'd rather use the stock frame and add on the crossmember and front suspenson and upgrade the rear suspension as I think it makes for a lot better truck in the long run unless you go for a whole custom fabricated frame like Morrison puts out.
My ongoing truck projects:
Old 07-18-2014, 08:15 PM   #11
ChuckDriver
RB's Obsolete, now out of business sold a bolt in clip, made be Kimbridge Enterprises, that used the G-body components.
See post 19 in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=421972
Old 07-18-2014, 08:22 PM   #12
Dan in Pasadena
Dan in Pasadena's Avatar
Man, the memory on some of you guys! I can't remember what I had for breakfast and you remember these threads!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 07-21-2014, 11:23 AM   #13
76er
OK thanks a bunch for all the sources, i'll check em all out
Old 07-21-2014, 12:56 PM   #14
mr48chev
mr48chev's Avatar
Contact info for Kimbridge Enterprises is listed as :
Address
7617 160th St SE
Snohomish, Washington 98296
Phone (425) 487-0763
No website that I can find and I don't know if they are still fabbing suspension pieces but it doesn't hurt to give them a call. They may be ghosting them for someone else's brand.
Old 07-22-2014, 12:15 AM   #15
tmoble
when the 70-81 Camaro/Firebird subframe is so good and so plentiful it's hard to figure doing anything else. Stock parts are everywhere, corner carver goodies available at all the usual suspect vendors. I did mine in 93, still driving it today, no issues. My sub came from a 79 WS-6 T/A, steering is just over 2 turns lock to lock, has 1.25" stabilizer bar. What's not to like?
And you can get the right B-Body spindles, use the 12" brake setup, still with all stock parts you can buy anywhere. bolt on.
tmoble is offline   Reply With Quote
Old 07-22-2014, 09:23 AM   #16
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have a Kimbridge clip (not selling it) and it is a real nice clip that accepts S10 A and G body parts which are almost falling off trees here.
dwcsr is offline   Reply With Quote
Old 07-22-2014, 10:04 AM   #17
76er
Tried to go on their site, says they are closed down
Old 07-22-2014, 10:07 AM   #18
mr48chev
mr48chev's Avatar
I never heard much out of them after RB's packed up and moved to Arizona and then folded. A lot of car and truck goodie outfits folded about that time though.
