Just Got a 61 Panel
I just picked up a 61 Panel from a good buddy who is getting married. Its got a 327/700r4, and freshly rebuilt brakes.
Its going to need a gas tank, and I can't seem to find one for the 60-62 panels. 63 and up are everywhere, but apparently the frame rails are different. Can anyone point me in the right direction? Here are a couple pics of the panel: ![]() Front clip needs to be put back on. I have it all though... ![]() |
![]() Join Date: Feb 2011
Re: Just Got a 61 Panel
Nice Panel Blown240; this ad has parts listed. Not familiar with him.
http://sandiego.craigslist.org/ssd/pts/4521697509.html
MusicMan70 1961 GMC Suburban |
Thanks music man. I forgot about that guy. I actually bought some parts off of him for my 66 suburban I had years ago.
Well the guy in Chula Vista never got back to me. I realized that his add is over a month old. I guess Ill have to find a tank from something else.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
you could go with aluminum, call Boyd welding
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I used a 22 gallon poly tank in my 62 it has the X frame and is larger in rear. Poly tank came out of a 92 Caprice wagon. Grab the mounting straps if you go this route. Got some photo's in my album's page.
Sweet! Thanks notsolo.
GMC Pauls says their Blazer kit will fit (adapt) 60-62 - this is the solution I am looking at.
http://www.gmcpauls.com/pictures/63-72tankkit.jpg |
![]() Join Date: Sep 2011
A Blazer tank is what I used in my 63.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
I guess this thread will become my build thread.
I got the truck home tonight. It was the first time I was able to really check it out and I got a lot better deal than I thought! Turns out I am the 4th owner, and it only has 70,000 original miles!!!!!! I really wish it still had the original engine and trans, but I can't complain about the 327 with a 700r4! It sat in the desert for most of its life, so its pretty rust free. It doesn't charge, so I need to check the wiring and probably put an alternator in it. And it only has headers right now, no exhaust, so thats one of my first priorities. also the idle is really high, and it shifts really late. But it runs, drives, turns, and stops. And the gas gauge always reads full! A tank gas and sender are also on the list... Here are the pics: ![]() ![]() ![]() ![]() |
Looks good, enjoy it.
WOW wish mine looked that good LOL
#13 |
What do you guys think of this tank? I need to double check the measurements, but it should work...
http://www.summitracing.com/parts/rn...er?prefilter=1 |
#14 |
#15 | |
Scottie |
#16 |
Thanks!
I took the truck out for the first real drive yesterday. It has a strange knocking, or tapping sound coming from the front wheel. Sounds like maybe something stuck to the drum, or maybe a bad wheel bearing. Also, the 700r4 isn't set up right. It shifts real late under part throttle. I only got on it once, and it won't downshift. Im going to have to look into that ASAP, so I don't burn the trans up. But for sitting in the desert forever, its doing real good! |
