07-17-2014, 04:51 PM | #1 |
Glove Box
One modification that just popped up is now that I have installed my Vintage Air system, almost all of the glove box space is gone except for 4 inches. My first thought is to simply lock the glove box and not worry about it. But I would like to be able to use the 4 inches of space. Anyone else run into this problem? If so what did you do?
1953 Chevy 3 Window Truck 3100 Series |
07-17-2014, 05:02 PM | #2 |
Re: Glove Box
I am also very curious about this as I am getting ready to put a Vintage Air system in my 51. How about some pics so we can see what you are up against?
Cheers, Chris 1951 Chevrolet 3100 Pick up |
07-17-2014, 07:07 PM | #3 |
Re: Glove Box
My used system came with plastic insert, maybe 3-4" deep. I figure a good place to keep the registration, insurance certificate, bottle opener and a road map. I added storage under the seat and will have more behind the seat too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
07-17-2014, 08:04 PM | #4 |
Re: Glove Box
Here you are Half Baked. This photo does not show depth perception, but the hoses as well as the unit are about 4 inches from the dash. You can clearly see that the glove box will not fit.
07-17-2014, 08:06 PM | #5 |
Re: Glove Box
OrrieG, please show me what yours looks like.
07-17-2014, 10:14 PM | #6 |
Re: Glove Box
I am using a VA unit in my '51 also - I didn't like the recommended placement/fit at all - I moved it more to the center of the cab and lowered it 3"- now the floor heating will flow to both sides instead of just the center/pass side. I now have more room for the vent/air piping and Everything else, including a complete stock glove box.
07-17-2014, 10:36 PM | #7 |
Re: Glove Box
I built a console so this placement would not be an option. It is installed the only place it could be installed.
07-17-2014, 10:39 PM | #8 |
Re: Glove Box
I had the same challenge after installing my vintage air set up. I simply used a a stock glove box liner and I cut 3-4" off the depth of the liner and used was left to recreate a new back wall of the shortened liner.
It sounds more confusing than it was to accomplish. I will take some pics of mine tomorrow. In the meantime I also installed a cigarette jack in the glove box as well. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
07-17-2014, 11:09 PM | #9 |
Re: Glove Box
I cannot cut and paste from my phone,look at post 730 in my build thread.
07-18-2014, 12:50 AM | #10 |
Re: Glove Box
I have the newer GenIV Vintage Air unit in my '57. The plastic glove box is less than 2" deep.
07-18-2014, 01:22 AM | #11 |
Re: Glove Box
Are you guys with AD's and Vintage Air happy with the system?
'55 3100 1st Series |
07-18-2014, 11:33 AM | #12 |
Re: Glove Box
Here is my factory cardboard glove box that I shortned up to clear the VA unit.
Marc
07-18-2014, 11:39 AM | #13 |
Re: Glove Box
Back at my desk, here is a photo of the VA insert. The PO cut it vertically to make it easier to get in. It fits to the inside really good one its in there and used the stock screw mounting points. I have not installed the door yet, but VA says you have to shorten the curved flat pieces that hold the door in place when open, do not know if I will like that may need to figure out a work around.
07-18-2014, 12:20 PM | #14 |
Re: Glove Box
WIDE LOAD C-30
I actually have not powered mine up, but will tell you once I have. The ones I have seen in operation worked great. The people I know who have them are well pleased, so I will probably be as well.
07-18-2014, 03:00 PM | #15 |
Re: Glove Box
Same problem here, so I made a custom glove box out of sheet metal and also made my own custom vent plenums.
07-20-2014, 09:10 PM | #16 |
Re: Glove Box
Roger55,
What did you use to make this glove box insert. What type plastic.
07-20-2014, 10:30 PM | #17 |
Re: Glove Box
I made the glove box out of 18g sheet metal. Shape the back to the outside dimension of the glove box hole then took a long piece of 18g 4" wide and form it around the back piece and tac weld it as I wrap it around. I also form the top part to miss the latch. Was not to hard to make.
07-20-2014, 11:09 PM | #18 | |
Re: Glove Box
And, my wife is going to line the inside with some of the same tan vinyl on the seat. She's going to put some pockets on it too so it will hold a wallet, phone, iPod or whatever. Last edited by roger55; 07-20-2014 at 11:21 PM. |
07-20-2014, 11:46 PM | #19 |
Re: Glove Box
Apparently they do not make this item for the system used in my truck.
07-21-2014, 12:15 PM | #20 | |
Re: Glove Box
the roundy thing is my duct to the va floor vent and the square hole is the outlet. should have put it higher as my toes get frosty
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
07-21-2014, 01:14 PM | #21 |
Re: Glove Box
Neat idea if you mount the VA system in the middle.
07-21-2014, 04:21 PM | #22 |
Re: Glove Box
My system came with the plastic insert also.
07-21-2014, 04:56 PM | #23 |
Re: Glove Box
I have a V A in both of my AD trucks and this time of year it takes a long time to cool the 140* inside temp inside the black truck down to at best 40* at the vent.
By the time the the high speed fan air is 12 inches from the vent is is not very cool! Most of my city driving is 20 to 30 mins and the truck is not cooling off very fast, so is it the black exterior or all the glass of the 5 window? The floo,r firewall, doors and roof are double insulated and carpet on the floor and behind the seat (3 layers). When it is over 105* ambient it is just hard to cool. My newer trucks (78 & 03) seem to cool much better with factory setups stronger blower,fans than the V Air fans.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-21-2014, 05:11 PM | #24 | |
Re: Glove Box
I suggest you take it to someone who is really experienced. With R134a, it's really important to have just the right amount of refrigerant in the system. Not quite enough or even a little too much can hurt the performance a lot. The right amount of oil is critical also. A little low on oil and the compressor can run quite a bit hotter. You need to measure the temperatures of the compressor itself, the top of the condenser and the bottom of the condenser as well as the pressures to make an assessment of the cooling efficiency. Moisture in the system and not enough air though the condenser will be big problems too. Everything needs to be assessed. And btw, the vents in my '57 pickup blow very hard with the VA unit I have. I know a guy in Sierra Vista really well that is fantastic with this stuff and is very reasonable. He's had professional training on auto a/c up the wazoo. Don't know how far that is from you though. |
07-21-2014, 05:12 PM | #25 |
Re: Glove Box
One with a box and one without, I do like the idea of cutting up a card board insert to fit .
I will have to do that to the 53
