07-17-2014, 07:34 PM | #1 |
New Lift for 72 k5
I want to put a new lift on my blazer. I think it may have had a 4 inch. But unsure. it has sagged a lot.
running 33 inch tires. Will Do some hill climbing. Right now the back hits when I go up the hills. Rides ok in the dunes but rides like **** when you hit bumps and dips on the street. Let me know of some good brands and deals. Thanks |
07-18-2014, 12:13 AM | #2 |
Re: New Lift for 72 k5
Off the shelf there are many different brands. Not sure about deals but I would suggest dealing through "offroaddesign dot com". They have a lot of experience in tailoring something specific for your needs. They deal primarily with Tuff Country brand I believe or can custom design a set of springs (Alcan) at a premium price.
My 2 cents. Cheers.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
07-18-2014, 12:19 AM | #3 |
I used a Tuff Country with springs all around. Does yours have blocks in the rear? If so, you could probably do rear springs (4") and see where you're at.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
07-18-2014, 12:41 AM | #4 |
Mine does have blocks in the back. Any of you guys go without blocks?
07-18-2014, 12:52 AM | #5 |
SKINNY TIRES RULE!
You could go with the Alcans but get 5" springs made so you don't have the blazer "saggy butt" issue. The other option would be a 4" spring kit and some zero rates to center the wheels in the wheel openings and add and extra 1".
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-18-2014, 01:08 AM | #6 |
Or you could do a shackle reversal with zero rates like Bouncy said and run stock arch springs to get you in the 5" or so range. With no blocks.
1972 Blazer build: http://67-72chevytrucks.com/vboard/s...d.php?t=615744 |
07-18-2014, 06:57 AM | #7 |
One of the First
I run a skyjacker 2.5" lift with their HD springs in the rear (no blocks), Sky jacket nitro shocks and 33" tires. Sits level and rides comfortable. Handles well on road and off road. I would recommend putting new shackles on the rear springs too. Might be pricey but worthy investment.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
07-18-2014, 12:37 PM | #8 |
I went with 4" kit from BDS, haven't had it on the dunes yet around here.
07-19-2014, 10:48 PM | #9 |
SD truck springs did me right ! Google it
07-19-2014, 10:52 PM | #10 |
An all spring lift is the best way to go. Blocks is a cheap route to go keep saving till you can get an all spring lift you'll be glad ya did!
07-19-2014, 11:13 PM | #11 |
That 2.5 lift sits perfect in my opinion...
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
07-20-2014, 09:47 AM | #12 |
Off the shelf tuff country seams to be what people like best. Alcans from ord are going to ride like a Cadillac and flex the way you want. The can make them any way you want.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
