Old 07-17-2014, 08:46 PM   #1
Thebrownturd
wheel size question
What is the stock wheel size for a 77 3/4 ton 4x4 Chevy. I might be able to get a good deal on them.
Thebrownturd is offline   Reply With Quote
Old 07-17-2014, 10:04 PM   #2
viking427
Re: wheel size question
16x6.5, 8 lug made by Kelsey Hayes. Should have a small "KH" stamped somewhere on the rim, usually near the valve stem. Painted off white originally. OEM on the 74-87 C/K20 & SRW C/K30 ..and a little longer on 3/4 & 1 ton vans/burbs. 73 & earlier were a bit narrower at 16x6.0.
http://67-72chevytrucks.com/vboard/s...d.php?t=621735 (conversation I had with myself)
viking427 is offline   Reply With Quote
Old 07-19-2014, 07:15 PM   #3
airdale94
airdale94's Avatar
I do alot of talking to myself on here also.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
